Hi all,
Since Rowan is almost done with his entry, I think it is time I show my progress...
I'm entering the Group Build with Planet Models' 1:48 scale Bugatti 100P resin kit. A review of it can be found
here. It's a simple kit with a small number of parts, perfect for a quick build. There's no need to glue the wings and the tailplanes to the fuselage as the airframe comes in one piece. You just have to clean the model and it is ready for painting! On the picture below, you can see all the parts of the kit. I only added one air scope just aft of the cockpit (modified plastic part from the spare box) and four access panels on the top of the fuselage (made out of self-adhesive aluminium foil). I have also rounded the edges of the cockpit's side consoles to make them look more like the real thing. Apart from that, the model will be done out of the box. The resin looks dirty because I've applied a wash to reveal the surface imperfections. There were not many...
Once the preparation work was done, I've sprayed the overall Blue color. For this, I've used my bottle of Tamiya X14 Gloss Sky Blue mixed with some Tamiya X-21 Flat Base to obtain a mat finish. I'm not sure if this is the original Tamiya X14 color though. It looks very dark so I may have use a darker mix from a previous project that remained in the bottle...
The model was then coated with Klir (French variant of Future). That's why I've added Flat Base to the paint...
Finally the surface was sanded smooth with fine grit sandpaper and polished using Tamiya's Polishing Compound. That's the white stuff which is visible in the panel lines. I still have to remove it from the model...
Next will be to paint the detail parts, glue them to the model, add some very light weathering and the model will be finished...
