Two Seater Campaign Roden Raf B.E.2c Terri
Guatemala
KitMaker: 343 posts
AeroScale: 111 posts
Posted: Saturday, March 06, 2010 - 08:39 AM UTC
Which one are you thinking about doing?
Well, as today I was thinking about the Eduard Fokker D.VII O.A.W.; it has lozenge, it's a biplane and as far as I know, doesn't have rigging. so will be a nice start for me. what do you think?
Let's do some plastic.
Byron
If you are not part of the solution, Don't be a part of the problem.
Posted: Saturday, March 06, 2010 - 09:38 AM UTC
Byron
Excellent choice for your fist WW 1 subject . Only rigging is on the landing gear and bracing wire for the rudder fin . Another good choice would be the Fokker Dr.1 or even the Fokker E.V / III .
I'm reading your palm right now and it is telling me you should buy one even a few , because you will get hooked and there is no turning back ..............
Guatemala
KitMaker: 343 posts
Posted: Saturday, March 06, 2010 - 10:21 AM UTC
I am afraid that you are right on that
, I feel the need for some dental floss (as in bundle of thin nylon filaments or a plastic (Teflon or polyethylene) ribbon)
Byron
Victoria, Australia
KitMaker: 608 posts
AeroScale: 602 posts
Posted: Saturday, March 06, 2010 - 11:51 AM UTC
Thanks Hugh , I'm planning on adding some ( u ) shape straps by drilling two small holes on either side and fixing them in place .
Which is exactly what I did.
The Cabane struts, on my next build of this kit, will be replaced by a length of Brass Alloy (very high tensile (for Brass), I cannot recall where I came by them) pins and then the strut bulked out with styrene strip. The Brass pins will be set fairly deeply into the Sides of the fuselage to add strength.
Part of my issue, if I remember correctly (I was at this point two years ago), was that the Kit is structured in such as way that if you cut off the nose (as we both have done) then there is no secure point to attach the forward pair of struts.
You will find too that you will need your rigging to be functional. And if you don't do this process (rigging) in a systematic way, every thing will be skewed.
Hugh
Östergötland, Sweden
KitMaker: 1,058 posts
AeroScale: 1,004 posts
Posted: Monday, March 08, 2010 - 08:57 PM UTC
So Sweet and so sad she´s not finished up Hugh. Whats stopping you? the prop? use the kits and ending this build.
Larsa
Victoria, Australia
KitMaker: 608 posts
Posted: Monday, March 08, 2010 - 10:23 PM UTC
I will finish her one day Larsa.... Your builds are making me jumpy.
The prop was put to one side. I will use the kit prop. 1/48 is just too small a scale to try a wooden one (unless I can find some timber that is more consistant... And I may just have some!).
Hugh
Posted: Tuesday, March 09, 2010 - 01:19 AM UTC
Hi Hugh , I recall your build on this and wonder what happened of it not being finished yet .
Have to agree with Lars , use the kit prop . It's such a fantastic build to be left undone .
I was planning on running tubing through the fuselage for the front lower wing spar . But the amount of work which was needed in the cockpit on redoing ever thing would take me until Christmas time , which I don't have . ( this was to be out of box ) It didn't go that way
West Virginia, United States
KitMaker: 1,121 posts
AeroScale: 1,063 posts
Posted: Tuesday, March 09, 2010 - 02:15 AM UTC
Nice work on the build, Terri. That was some major surgury but you pulled it off like a pro! This will be a nice build, can't wait to see it finished.
Arizona, United States
Posted: Tuesday, March 09, 2010 - 08:11 AM UTC
Nice Build Hugh! Great craftsmanship.
We few, we happy few........
Posted: Sunday, March 14, 2010 - 08:13 AM UTC
California, United States
KitMaker: 16 posts
AeroScale: 15 posts
Posted: Sunday, March 14, 2010 - 01:11 PM UTC
Beatiful job so far, Terri. Love how you did the framing. Nice work on the engine. I chose to cover mine (still pretty exposed). Since I've been working on it since November, I just want to finish it. Have you decided on a scheme yet? Have you seen the builds on the Roden site? There's a really nice one by Michal Sudek from the Czech Republic. It's the kit sceme with the Union Jack. Looks a lot better than it does in the Datafile or kit instructions. Keep up the terrific work. Can't wait to see her all dressed up.
Bud
Posted: Sunday, March 14, 2010 - 03:26 PM UTC
Thanks Bud
Scheme you ask ..............some thing I will have to decide on soon here and quit changing my mind . The fuselage and tail pieces now have there primer . The little bits left for the engine can be added with fear of ruining the paint once it has been applied . Masking of the frame work will start after the prime has dried for a few days .
I do need some help though on the lead wires for the spark plugs , were are this hooked up to ? Not very clear pic's in the datafile , put does have a lovely pic of the sump pump !
Victoria, Australia
KitMaker: 608 posts
Posted: Sunday, March 14, 2010 - 11:12 PM UTC
Hi Terri,
The Spark Plug Leads run back to a platform at the rear of the Crank case that holds the Magnetos (two of them, one for each bank of cylinders). I will see if I can find a photo for you.
Hugh
Victoria, Australia
KitMaker: 608 posts
Posted: Sunday, March 14, 2010 - 11:24 PM UTC
Unfortunately, all I can find at the moment are shots of the engine details I did for my BE2c.
I will keep looking.
Hugh
Posted: Monday, March 15, 2010 - 01:08 AM UTC
That is perfect Hugh . Thank-you very much for your aid . I'm not planning on going nut's with the detailing , but since the engines panels are off there is this big empty space so it does need something to fill that void . Maybe by the end of the week these parts will be added to the block , but here's to hoping !.
Nice job on the oil sump
Victoria, Australia
KitMaker: 608 posts
Posted: Monday, March 15, 2010 - 08:17 AM UTC
Hi Terri,
That's my slightly oversized rendition of the Claudel Hobson twin Carburettor. The induction pipes from the carby are cast integral with the back plate of the crank case. The carby bolts to the bottom of the back plate and the Induction pipes extend from the top and forward along the cylinders.
Hugh
Posted: Monday, March 15, 2010 - 02:37 PM UTC
Hi Terri,
Hugh
Okay so I don't know a hell of alot about engines , thanks for the clarification Hugh
You did render the part very well .
Here is what I managed to get done this evening .........................
New York, United States
KitMaker: 365 posts
AeroScale: 344 posts
Posted: Monday, March 15, 2010 - 02:50 PM UTC
Terri,
Looking very good.
Dwayne
Posted: Tuesday, March 16, 2010 - 12:44 AM UTC
Terri,
Looking very good.
Dwayne
Thanks Dwayne
Texas, United States
KitMaker: 365 posts
AeroScale: 356 posts
Posted: Tuesday, March 16, 2010 - 02:47 AM UTC
Terri,
Wow Hugh did a fantastic job on the engine for his BE-2. Not a doubt in my mind your example will be equally as well done. Keep up the excellent work.As always your updates never fail to be most impressive.
Highest Regards,
Gregory Jouette
Posted: Thursday, March 18, 2010 - 12:48 AM UTC
Terri,
Highest Regards,
Gregory Jouette
Thanks Gregory . I have finished adding the detail and primed ready for paint now . I also had to redo the front framing do to it being drop on the floor nose first , which turned out rather well . Didn't care for the detail I added and found some better items to use within the spare parts . Will have pic's up of this later tonight ................................
Connecticut, United States
KitMaker: 424 posts
AeroScale: 389 posts
Posted: Thursday, March 18, 2010 - 01:58 AM UTC
Terri
On
www.Flightglobal.com in the Archive section, search for Rigging, for the date; From: 1918, To: 1918.
The article for November 21, 1918 is the rigging manual for the BE-2C. An interesting read fo those who are doing this model.
Enjoy
Captn Tommy
Posted: Friday, March 19, 2010 - 12:35 AM UTC
Terri
On www.Flightglobal.com in the Archive section, search for Rigging, for the date; From: 1918, To: 1918.
Enjoy
Captn Tommy
Thanks Tom for the info . I've been on the site before and it is a excellent site of info
Posted: Sunday, March 21, 2010 - 02:57 PM UTC
Västra Götaland, Sweden
Posted: Sunday, March 21, 2010 - 07:25 PM UTC
Hi Terri,
Looking really good so far, like your build a lot, and like the B.E.2c!
