Finally, some significant progress; I'm just about ready to button her up.
The sequence of construction for the cockpit was rather complicated; I wanted a fully rigged flight control set up and that necessitated a "one sided" approach. (The cockpit detail had to be built into one side of the fuselage prior to "close up".)
Over the past couple of days I've completed the control stick add-ons including throttle and cables, gun trigger wires, control locking lever and all associated flight control cables. It looks pretty "rough" here, prior to final painting, but once painted and installed, I was very pleased with it.
The comparatively small number of components for the left fuselage side were completed and installed; the magneto wires and spark advance control rod were "scratched" from sprue and copper wire respectively and the magneto key and chain were added from the Eduard PE Set. Note also the partial fuselage former that was cut away earlier and installed on the left Fuselage half to accomodate routing of the mag. wires and spark control rod.
The fairlead openings for the elevator control cables were drilled out and cleaned up. I'll be adding the Photo Etch fairlead grommets prior to painting the fuselage.
And now the cockpit; very busy in there! Additions were the Aux. Throttle seen on the extreme left, the altimeter and clock on either side of the Tachometer on the heavy pipe cross brace/LMG Mount (Done with Waldron punch bases, Aeroclub bezels, and WNW Decal faces with a coat of Future to form a lense.) , and of course the flight control stick finally in place. Once the stick was positioned and secured the flight control (elevator) cables were tightened and secured with CA.
Here she is in all her "Pre Button UP" glory; a lot will not be visible however I know it's there. The only detail left out were the aileron control cables from the wheel on the joystick base going up (eventually) to the upper wing. Those will be added from upper wing down into the fuselage behind the fuel tanks once the upper wing is in place.
So now I'm ready to button her up. I'll be doing that tomorrow along with a lot of drilling for rigging points and getting the forward (engine compartment) formers and engine mounts done.
I am really looking forward to getting some paint on the fuselage and getting at the wings etc.
Thanks for looking and all comments welcome!
Lance
