I started my Hornet not with the cockpit, but with the wings
Simple reason: I still have not decided yet, which version. The CA kit basically allows you to do every Hornet and Sea Hornet, you just need the decals.
So I started with the wings, heavily influenced by two great builds on Britmodeller.
I opened the cooler outlets and the wing under the nacelles for further detailing.
It seems, that the position of the landing gear is slightly wrong. It should be on the main wing spar (logically), which can be clearly seen under the wing, so it is more aft then int he kit. So I had to move the opening backwards This will give at the end little steeper position of the plane.
While doing, I started to detail the gearbay with some pipework, frames and slightly narrowed Mosquito oil tanks.
Cut out the position lamps and replaced them with clear plastic, and prepared the landing light for glazing.
I already installed the spinner back plates and covered the exhaust openings from the inside, because I prefer to install the exhausts last and needed to close the nacelles.
As mentioned before there are discussions of people who have original drawings from de Havilland, that the nacelles have different length due to the handed engines. However as these plans are not published, I will not do it. The plans in the Warpaint book should be not really correct.
Seems also that the spinners and the fuselage are to short.
The usual problem, you want to do your best and then somebody comes and tell you the drawings are wrong However until better drawings are out, there is not much you can do. No real plane left.
At the end I build for fun
Greetings from Shanghai
