On another note, the Nimrod has had the undersides painted and masked up ready for the Hemp coat.
Painting again tomorrow.
Warren
Hi Warren,
looks nice! And awfully big!
Greetings from Shanghai![]()
Looking great Warren!
Right, moving on with the Sea Vixen - the airbrake bay is in:
This next part really demonstrates the value of test fitting EVERY PART EVERY TIME!!!![]()
Having put together and painted the intake liner tubes, I test fitted the Y shaped part, only to discover that if one side fits, the other side is out by 3-4 mm:
The only solution is to separate the tubes, glue the ends into the intake ducts, and use the fan faceplate to line up the other end while they set:
Also today, I have installed the undercarriage bays, and after test fitting the fuselage halves together, realised I need to thin the tops of the bays, or the wings won't join properly. Also, in the next pic, you can see I have begun to thin the trailing edges of the wings. I can tell I'm going to enjoyputting the fuselage together!
To quote someone who commented on a build log of this kit that I am following, "This kit really sorts the model makers from those who merely assemble kits". That just about sums this kit up, shake and bake it certainly ain't!
@ Warren
Great Nimrod! How do you build so fast and still good?
I am much slower and feel I need much more putty and my surfaces are never so good.
Will you do some weathering?
Progress, got it pulled together, masked and primed.
