Since I know next to nothing about modeling jet aircraft, This is going to be a real learning experience for me.
I started off with the front wheel well assembly, which is comprised of 4 sections to form wheel well, and the bottom of the cockpit that will serve double duty as the top of the well.
The individual parts all have some detail, but the overall effect is kind of sparse, so I decided to busy it up some. The top has 5 ribs that are all the same height. The 1st 3 should be twice as tall, so I added some .040 sheet plastic to increase their height. I added some pieces of scrape plastic to represent electrical boxes, and used 2 different dia. of wire to represent electrical wiring along the two long walls and for the floor. I also added a pump and valve assembly.
I wanted to see the full effect, so I primed both sub assemblies with Tamiya Gray lacquer primer thinned 1;1, & applied with my airbrush @ 10-12 psi. The results were exactly as I had hoped. While by no means does it comes close to the amount of wiring and plumbing in the actual aircraft, it does busy up the wheel well to a satisfactory level.
At this point I'm going to skip working on the cockpit, and turn my attention to the main gear wheel wells. Then paint all three of them at the same time.
