Well, it's time for another small but major step forward update.
Yesterday, I received both my new Iwata Revolution M-1 air brush, as well as not one but two sets of masks from our own Mal of Miracle Masks. I'd call that one great day.
So last night while watching the Yankee baseball game, I read the instructions on how apply the masks. Mal has done an excellent job to help us newbies over the fear of screwing up applying them. I figured it would take me a few days to get them right. I started with the Horizontal rear stabilizers, figuring that they were the easiest to do.
I started off at a snails pace, and had a little trouble with proper positioning caused by me, not the masks . But once I got use to working with them, and over the fear that I would damage them if I pulled, pushed, or lifted too hard. I found that the masks are very durable, bendable, and show no signs of stress or damage from my 1st few clumsy attempts. In short order I got reasonably comfortable applying them, and even the larger masks weren't a issue if you followed Mal's instructions. There are some cut outs to help the masks conform over bulges, and I did need to cover a few seams to play it safe, but the process didn't take nearly as long as I thought.
There is one large mask, #8 that goes both above and below the rear horizontal stabilizer. Mal supplies an extra one just in case you damage it. I had no such issues, but it's rare that anyone thinks of that and supplies a back up.
Mal, I can't thank you enough.
Tonight is the 1st of two overnight shifts I do each week at work, so after my coffee it was time to get up close and personal with the M-1. Oh my! This is without the best airbrush I've ever used. The precision and control of the spray pattern of an internal air brush, coupled with the smooth flow rate that I've come to expect from my Paasche H external air brush, made the learning curve like 5 min.
So it was time to air brush on the Tamiya Dark Green XF-81 thinned 1:1 with Tamiya's Lacquer Thinner. I decreased the flow rate from 18 psi that I use with the Paasche H to 16 psi and worked a little closer to the surface. The paint just flowed on as smooth as silk. Needless to say, I'm one happy camper.
Here's a few pictures of the camo paint scheme. It's as perfect as I can get it. Thanks to Mal's masks, there wasn't a drop of over spray or paint running under the masks.
