OFFICIAL: The Sign of the Four Campaign
#523
Idaho, United States
KitMaker: 342 posts
AeroScale: 250 posts
Posted: Thursday, December 01, 2016 - 10:51 AM UTC
Well here is the Lamborghini Countach Quatrovalve
Interior
Brake Lines added
Finished model
#523
KitMaker: 342 posts
Posted: Thursday, December 01, 2016 - 10:53 AM UTC
BTW, This was a Testors Fujimi Kit and no matter how much dry fitting I did The body and frame wen together like crap.
The doors did not fit well, windows a nightmare and just not that fun at the end.
MichaelSatin
KitMaker: 3,909 posts
AeroScale: 2,904 posts
Posted: Thursday, December 01, 2016 - 05:26 PM UTC
Sorry to hear that Jeff. At least it looks great!
Michael
On the bench:
#305
Christchurch, New Zealand
KitMaker: 1,673 posts
AeroScale: 1,517 posts
Posted: Friday, December 02, 2016 - 06:09 AM UTC
I agree with Michael nice work Jeff! Great to see and wheeled thing finished and looking fine!!!!
New Jersey, United States
KitMaker: 330 posts
AeroScale: 286 posts
Posted: Saturday, December 03, 2016 - 07:37 PM UTC
nice job jeff. way to hang in there and finish. i feel ya, seems every car i have built recently i have had one problem after another. nice work on the engine too.
joe.
KitMaker: 330 posts
Posted: Saturday, December 03, 2016 - 07:42 PM UTC
pictures posted in the gallery
Ontario, Canada
KitMaker: 2,507 posts
AeroScale: 1,814 posts
Posted: Sunday, December 04, 2016 - 02:09 AM UTC
Gloss black on, next up masking and Alcad:-
" The Die Hards"
43rd MIDDLESEX REGIMENT
MACHINE GUN CORPS
XXX CORP
- Amelia Earhart
United States
KitMaker: 42 posts
AeroScale: 42 posts
Posted: Sunday, December 04, 2016 - 04:20 AM UTC
Hello All
Sorry its been so long since my last update!!
I have finally finished the P-40B from Pearl Harbor
I feel that the cammoflage came out a little too dull but other wise i am happy with it
#523
KitMaker: 342 posts
Posted: Sunday, December 04, 2016 - 09:23 PM UTC
Thanks all for the nice comments.
Joe, Your right every time I do a car it is hit or miss when it comes down to the body fit and attachment, especially when there are door that are designed to open.
I have probably have 15 to 20 other Lamborghini models. I have heard good things about Aoshima and have quite a few Lambos from them that I can not wait to work on.
Joe - BTW-
I like the cowling on the Corsair.
#523
KitMaker: 342 posts
Posted: Sunday, December 04, 2016 - 09:53 PM UTC
FYI
I used for the first time, Createx Wicked Colors Airbrush Paint (Pearl White). I wanted Model Masters or some other paint but no stores in town had any.
I had read that it did not make a difference what you primed with. SO I primed with Tamiya primer gray. After 4 coats of the pearl, the body looked Silver. This meant I had to start again with a flat white primer.
I will say the Wicked airbrush paint says "Airbrush ready" it looked a little thick out of the bottle. I was surprised that through my Badger 105 Anthem, That I only use for large coverage areas it work fine at 25-30 PSI rather nicely.
The coats also built up rather well. The pics do not show it so well. but it is not that bad of paint.
KitMaker: 330 posts
Posted: Monday, December 05, 2016 - 12:55 AM UTC
FYI
you know it does look pretty good. i plan on doing a pearl white race car soon. i will check it out. i just noticed the shoulder seat belts. pretty neat addition, you scratch make them or with the kit?
joe
btw- the cowlsnake is the reason i did this corsair.
KitMaker: 330 posts
Posted: Monday, December 05, 2016 - 12:59 AM UTC
rodney it looks good to me. you have to remember it probably sat on the runway in the sun so it would fade. i am interested in how you rigged the antenna. i am thinking on doing a AVG plane and want to rig it the same.
joe
United States
KitMaker: 42 posts
AeroScale: 42 posts
Posted: Monday, December 05, 2016 - 05:42 PM UTC
Joe
I used a product called EZ-line, it is stretchable/elastic I measures wing to wing then pull it back to the tail. Used super glue to attach
Hope that helps
Rodney
#523
KitMaker: 342 posts
Posted: Monday, December 05, 2016 - 08:45 PM UTC
Joe,
The seatbelt hardware came with the kit. Yu were supposed to cut the straps from the paper instruction sheet but I uses a thin lint free tech wipe stained black.
I will let you know that the Createx Wicked airbrush paints although they can be used on multiple surfaces, seem primarily designed for other uses than modeling. The reason I purchased it was it was in out Hobby Lobby where all the modeling and airbrush stuff was.
Here is these quick pitch.
Great for fabric to automotive applications. Wicked Colors are perfect for t-shirts, automotive graphics, illustration and most any application. Wicked contains mild amounts of solvent inter-mixed with a durable, exterior-grade resign and automotive pigments for an extremely durable paint that withstands direct, prolonged exposure to outdoors elements without washing or fading.
KitMaker: 330 posts
Posted: Tuesday, December 06, 2016 - 12:22 AM UTC
Joe
Hope that helps
Rodney
yes i have heard of it. i been meaning to get some.
i was primarily interested in how you anchored it to the wings. i was thinking of using a hoop of fine wire in each wing and maybe drill a hole in the rudder to pass the line through.
joe
KitMaker: 330 posts
Posted: Tuesday, December 06, 2016 - 12:23 AM UTC
Joe,
sounds like it is a kind of automotive paint. maybe just needing a little thinning. is it a lacquer?
joe
#523
KitMaker: 342 posts
Posted: Tuesday, December 06, 2016 - 09:42 PM UTC
No it is acrylic and does have an automotive thinner you can use with it. I used Tamiya Acrylic thinner and it work fine but I think I thinned it a bit to much at first. so 2nd time through, I used it straight airbrush pressure to around 25 psi. Work just fine that way as well. No flow problems or splattering.
United States
KitMaker: 42 posts
AeroScale: 42 posts
Posted: Wednesday, December 07, 2016 - 08:00 PM UTC
[quote]
Joe
Hope that helps
Rodney
Joe
I didn't have a drill bit that fine but i was thinking that way too
Wales, United Kingdom
KitMaker: 242 posts
AeroScale: 2 posts
Posted: Saturday, December 10, 2016 - 03:58 AM UTC
#424
Queensland, Australia
KitMaker: 4,648 posts
AeroScale: 1,938 posts
Posted: Saturday, December 10, 2016 - 10:09 AM UTC
Wow guys, some truly great builds here. Congratulations!
Gaz
Frederick The Great
Berlin, Germany
KitMaker: 709 posts
AeroScale: 651 posts
Posted: Saturday, December 10, 2016 - 01:07 PM UTC
Rodney: Nice work on that P-40, colour looks to me reasonable. Good to see one more kit finished 4 the campaign.
Richard:Very cool 8-wheeler! Well done on the camo, subtle weahering and detailing, looks great.
Thomas
Sør-Trøndelag, Norway
KitMaker: 189 posts
AeroScale: 142 posts
Posted: Thursday, December 15, 2016 - 06:51 AM UTC
I think I'll call this one done! The HobbyBoss kit is pretty good, beside the fact they call out the wrong set of road wheels. The rubbery tracks was easily glued with Tamiya Liquid Cement. I also like that all the different tools are moulded separately as it eases painting a lot.
The finish is Black Citadel primer from a rattle can, and then airbrushed with Vallejo Model Color
70.889 US Olive Drab.
I added a couple more pictures in the Gallery.
Building the world, one piece at the time.
MichaelSatin
Posted: Thursday, December 15, 2016 - 05:20 PM UTC
Very classy Eric!
Only about another 4tnight all, let's wrap up those builds!
Michael
On the bench:
#298
Hong Kong S.A.R. / 繁體
KitMaker: 1,182 posts
AeroScale: 351 posts
Posted: Friday, December 16, 2016 - 10:30 AM UTC
#305
Posted: Saturday, December 17, 2016 - 07:18 AM UTC
