General Aircraft
Aircraft Trivia Quiz 2 (Join In)
Lawnguylander
KitMaker: 23 posts
AeroScale: 19 posts
Posted: Monday, April 18, 2011 - 02:59 PM UTC
OK, I am SERIOUSLY impressed that you got that one!!
madcat911
KitMaker: 112 posts
AeroScale: 31 posts
Posted: Monday, April 18, 2011 - 09:57 PM UTC
Actually.... no.
F-5S is very close though.
warreni
KitMaker: 5,926 posts
AeroScale: 2,201 posts
Posted: Monday, April 18, 2011 - 10:04 PM UTC
Actually.... no.![]()
I beg to differ. One of them is the cockpit of an F-5S, the other one is the cockpit of an F-5T....
madcat911
KitMaker: 112 posts
AeroScale: 31 posts
Posted: Monday, April 18, 2011 - 10:23 PM UTC
Well, the 2 photos are both of an F-5T. One is of the front cockpit and the other is of the rear cockpit.
So who wins?
So who wins?
warreni
Posted: Monday, April 18, 2011 - 10:34 PM UTC
I thought the front cockpit was the F-5S and the rear cockpit the F-5T.. You asked the question Sir so you are the judge..
madcat911
KitMaker: 112 posts
AeroScale: 31 posts
Posted: Monday, April 18, 2011 - 10:39 PM UTC
Well, you're the only one to bring up F-5T so, Warren, it's your turn.
architect
KitMaker: 91 posts
AeroScale: 83 posts
Posted: Tuesday, April 19, 2011 - 01:56 AM UTC
After all Waren found it first, and had the courtesy of giving us rest a go.
So Waren lets hear it from you.
warreni
Posted: Tuesday, April 19, 2011 - 08:22 AM UTC
Thanks Guys..
This is where I found my information about the cockpits..
http://www.arcforums.com/forums/air/lofiversion/index.php?t134804-50.html
Now, a nice easy one for you all.. and this is straight from memory of an article I read many moons ago, which aircraft had the largest main landing gear wheels?
architect
KitMaker: 91 posts
AeroScale: 83 posts
Posted: Tuesday, April 19, 2011 - 12:50 PM UTC
I'd say B-36 or XB-36. 110 inch diameter wheels in early stages. However it was later replaced by multiple wheeled legs.
jaypee
KitMaker: 1,699 posts
AeroScale: 1,384 posts
Posted: Monday, April 25, 2011 - 05:52 AM UTC
XHB-1 had pretty big boots for it's size, but not 110 inches!! Blimey!
warreni
Posted: Monday, April 25, 2011 - 09:15 AM UTC
Oops! Sorry for the delay.. You are correct Antonatos.
From Wikipedia - 'The tricycle landing gear system's initial main gear design, incorporating huge single wheels that would quickly be found to cause significant ground pressure problems, only allowed the B-36 to land at just three airports in the United States (Fort Worth, Eglin Field, Florida, and Fairfield-Suisun Field (now Travis AFB) in California[9]), mandated that Consolidated design a four-wheeled truck-type wheel arrangement for the main gear instead, which distributed the weight more evenly and reduced weight by 1,500 lb.'
Next question..
Next question..
architect
KitMaker: 91 posts
AeroScale: 83 posts
Posted: Monday, April 25, 2011 - 07:54 PM UTC
Well what do you know my first question.
Awright.... Here we go. From the beginning of aviation days, it is known that multi engined planes, have equally multi throttled cockpits. That is, number of engines, equals number of throttles on all planes…..except one. Please name the one. That's it guys and "Christos Anesti" (Easter wishes) from Greece.
warreni
Posted: Monday, April 25, 2011 - 09:41 PM UTC
Space Shuttle?
madcat911
KitMaker: 112 posts
AeroScale: 31 posts
Posted: Tuesday, April 26, 2011 - 05:42 PM UTC
Yak-38 Forger?
architect
KitMaker: 91 posts
AeroScale: 83 posts
Posted: Wednesday, April 27, 2011 - 12:48 AM UTC
Hi guys thanks for your answers.
Warren I’m afraid no. We are looking for a traditional atmospheric-powered and-controlled-flight-good old plane.
Mark, you got me thinking…but no. Yak 38 had a main engine with two nozzles, and two auxiliary smaller ones, separately controlled in the cockpit. I’m frantically trying to back it up with a photo, but no much lack so far. If supported otherwise, I’ll be happy to be wrong.
warreni
Posted: Wednesday, April 27, 2011 - 06:10 AM UTC
Antonatos, Having a bit of flying experience in multi-engine aircraft I can't imagine not wanting to control both engines independently in case of losing power in one engine and having to increase throttle to keep the kite flying straight.. Google has lots of cockpit photos if you need a source. But could it be the VF-22 Osprey?
architect
KitMaker: 91 posts
AeroScale: 83 posts
Posted: Wednesday, April 27, 2011 - 08:07 PM UTC
Good morning Warren.
I didn’t know I was speaking to an experienced airman. So I should say that controlling your engines independently, gives you the advantage of regulating power should something goes wrong….unless a guy called le computeur, does that for you. It is more of a designer’s choice, given the fact that no other example even newer ones, has incorporated such a thing.
As for the Osprey, yes there is only one throttle or Torque Control Lever as they call it, and it could qualify as an answer, along with every multy engined helicopter, because, the TCL controls blade pitch, more along the lines of a collective.
What I have in mind, is a traditionally operating airplane, with only one lever regulating the actual turn rate of two engines thus.
Cheers.
Cheers.
warreni
Posted: Wednesday, April 27, 2011 - 08:20 PM UTC
Not a problem Antonatos..
Yes, you are right about helicopters, but I wasn't classifying the Osprey as a helicopter... But that is a large bone of contention with anyone to do with the Osprey by the look of it..
Now lets see...
1. One throttle for two engines.
2. If that is the case then the engines may have to be close together to stop problems with asymetric thrust...
Am I on the right track?
Now lets see...
warreni
Posted: Wednesday, April 27, 2011 - 09:27 PM UTC
Soko J-22 Orao?
architect
KitMaker: 91 posts
AeroScale: 83 posts
Posted: Thursday, April 28, 2011 - 12:06 AM UTC
My friend Warre, there are many more hints in my previous answer. Anyway lets see.
You are right about the distance between the engines, but by chance... Why should it be a problem? If le computeur is doing all the hard job why couldn't he stabilise the extra torque? Err... no... no Orao Galeb.
jaypee
Posted: Thursday, April 28, 2011 - 07:23 AM UTC
Cessna Skymaster?
EDIT: naw, scratch that.
warreni
Posted: Thursday, April 28, 2011 - 07:55 AM UTC
Because computers can fail.. And there must be two then as the Soko has one throttle lever for two engines as well....
@ JP, I looked at the Skymaster very early on and it has two levers,, as does the Do335..
architect
KitMaker: 91 posts
AeroScale: 83 posts
Posted: Thursday, April 28, 2011 - 08:22 AM UTC
With your permission Gentlemen... http://www.mycity.rs/slika.php?slika=54111_198137142_Oraocockpitlijevo2.jpg j-22 has two levers. Now as for the side joystick, must be something of a weapons guidance of the Grom-1 Radio-guided AGM.
warreni
Posted: Thursday, April 28, 2011 - 08:34 AM UTC
http://forums.eagle.ru/showthread.php?t=30360
Read here about half way down,
"Cockpit is pretty old fashioned, russian sturdy approach but western electronics from '70s. Just note single throttle arm in a twin engine plane! "
architect
KitMaker: 91 posts
AeroScale: 83 posts
Posted: Thursday, April 28, 2011 - 08:47 AM UTC
Well I'm afraid he's wrong.
http://www.mycity-military.com/Avijacija-i-PVO/J-22-Orao.html
If you notice the lever in question, is rotating outside any slots you would find on any old fashioned throttle. Also, there is a corresponding similar lever on the other side. My guess is that it's the canopy activator.
On the first picture I sent you one can clearly read "GAS" on the mid rail of the two levers...and there you have your throttles.
