Thanks for the compliments folks!
That is brilliant work with the winter camo. How did you achieve it so well? Briiliant mate
I don't feel there's was any real trick to it, I just went over the model with Vallejo off-white, sort of scribbling away to make an uneven pattern, occasionally moving the airbrush closer to the surface of the model to form more prominent mottles. The key thing is that instead of trying to actually airbrush each and every mottle individually, I kind of just haphazardly doodled it on.
I also didn't stop and start airbrushing while pointing the airbrush at the model, instead always starting the air and paint flow outside the model (despite using and double action airbrush), pulling back the trigger and adjusting the spray pattern before moving over the model.
While I'm at it writing this, here's some more progress as well -->
The props pretty much finished and assembled. The instructions only indicated the tips of the spinners to be painted patina green, but photos of the real thing clearly show a dark stripe between the tip and the RLM70 the rest is painted. I settled on black.
Now here's Xtracrylics' RLM70 (spinners) and 71 (prop blades) side by side. There isn't much contrast between the two. From what I've read, that's accurate, but such difference would have been barely visible under the white wash, hence the artistic license.
Btw, how would paint chips look like on these wooden propeller blades? I'm thinking about doing some slight chipping on the spinners, but I have no idea how wooden prop wore down in use.
Landing gear doors painted up:
These required a little bit of trimming on the locator pegs and on the back edges of the outer doors to fit properly in the closed position for the painting of the exhaust stains.
Main landing gear ready to be installed. Putting the wheels in place scraped a bit of the paint off, so touch-ups are in order.
Oil cooler housings and exhausts attached, landing gear wells painted:
The panel lines are accented with Pro Modeller dark dirt wash. I also painted on some paint chips here and there.
Just what would we do without Eduard mask?
The designer of this mask set seemed to have forgotten the opening in the back of the dorsal turret dome (circled in pic). Not a big deal to touch up with a brush though.
Next I'll start worrying about aibrushing the prominent exhaust stains (anyone know good tutorials or articles on the subject or have tips to share?), finish the landing gear and start realizing that I'm getting closer to completion.
