that shop stick is creative! Way to pay attention to detail! Have you stretch formed before? I am hoping to try it sometime it looks fun, probably a bit of a learning curve...
I don't know what you're talking about, so I'll be watching this operation intently!
For my part, I worked up (measuring, remeasuring, cutting, remeasuring, trimming, etc.) legs for my pontoons out of styrene strip stock. No easy way to line them up that I could discern, except by eyeball. I attached the legs to the plane with normal Testors plastic cement, but set the bottoms into carved grooves in the wood pontoons and glued with a healthy dose of Aleene's Tacky Craft Glue, which dries clear.
and made bracing from finer strip stock (carefully choosing whatever size I had the most of!
and pontoons are done! I like the white, so I probably won't even paint the pontoon mountings.
The rubber band is to hold the cowl while my reglueing set, because it had split open during final assembly. There's no definite attachment point on the cowl of this Heller/Humbrol kit to sand and cement, so I didn't even use plastic cement-- I used craft glue instead, for a heavy coating applied around the outside of the cylinders that's sure to grab somewhere on the inside of the cowl for a decent hold.
Retouching the blue and painting and installing the prop next.
Cheers!
Sean H.
