.... development of the G-version began in late 1941 to meet requests by the Luftwaffe for further improvement of the aircraft. When development began, an engine that could fulfil some requirements was already available in form of the Daimler Benz DB 605. With more power this engine remained identical in size to its predecessor, the DB 601. Installation into the 109 airframe therefore proved to be relatively easy. The higher perfomance and greater engine torque however required structural changes in the airframe which increased the weight. The G-6 was fitted with a MG 151/20 (20 mm) firing through the engine block. The MG 17 mounted above the engine were replaced by MG 131 (13 mm). The belt-feed to the uprated armament made a redesign of the aerodynamic engine cover necessary, which gave the aircraft its characteristic bulges, hence its nickname "Beule". The G-6 was used extensively on all fronts from March 1943 until the end of the war. With a total of nearly 13.000 machines it was the most prolific of all Bf 109 variants ....
.... Italeri came out with this kit in 2011/2012 in their "Aviation Glory" series and named it "Italian Aces". The great decal sheet - made by Cartograph - offers 6 fantastic versions, 3 each from the Regia Aeronautica (RA) and the Aeronautica Nazionale Repubblicana (ANR). I decided for the aircraft of the 150. Gruppo, flown from Sciacca in summer 1943 during the battle for Sicily. The pilot was Maggiore Antonio Vizzotto, who was the CO of that unit during that time. You can see his pennant on the fuselage. He was one of the first Italians to fly the Bf 109 due to his flight experience during the Spanish Civil War and later in North Africa. During the air battles over Sicily he was credited with the kill of two B-25 Mitchell and the destruction of a Spitfire. As you can see, he flew a "Kanonenboot" (gunboat) with two underwing MG 151/20 gondolas. A "Kanonenboot" was more than a match for an enemy bomber but on the other hand it was heavier and slower, so it was also an easy prey for allied fighters ....
.... this kit is new with Italeri but it's an old acquaintance to us. Academy came out with this kit in 1994 and therefore it has some issues, just like the Buchon. I needed some filler to fill the gaps between fuselage and wings, also there was a lot of happy sanding to do. It may take some extra time but in the end this One-O-Nine also becomes a bella donna
.... I say "Mille Grazie" for walking around with me and hope you enjoyed looking at the photos. This is my last finished model this year. I wish you all a merry christmas and a happy 2014! See you all happy and healthy next year!
Happy modelling!
Torsten
