Indeed they are,
Jessie !
Welcome to my thread,
Russell! It's great to hear that you like what you see!
As I mentioned before, here comes Part 2 of my FiAF Mersu Dual Combo, this time it's the Bf 109 G-6, again from Eduard ....
.... on the 23. June 1950 the FiAF Air Base in Utti in the southeast of Finland held a Midsummernight Festival. They also arranged a "Reno Style" air race in which 4 special marked Bf 109 took part, marked as planes A to D. I have build MT-508 of HLeLV 31, which flew the race as plane B. At the controls on this occasion was Luutnantti Arvo Arima, a reconnaissance pilot from war times. The usual german camouflage of RLM 74/75/76 on MT-508 was painted over on the left fuselage with white and blue squares forming checkers plus the letter B in the middle and on the left wing. It's accompanied by further white symbols. It is believed that these checkers were only painted on the left side as the aircraft flew in circles around the pylons. This is the only known photo of MT-508 as plane B. I further found also a photo of MT-402 as plane D somewhere in the internet ....
.... like the G-2 this kit comes from the limited edition "Mersu - Bf 109 G in Finland" and offers the same high quality, though during the build I noticed here and there a slightly worse fitting compared to MT-230 from above. So I had to do a bit more sanding than on MT-230 (which was probably my own fault) but I also needed some putty at the connection of the right wing to the fuselage. But everything else went smooth. Eduard has for sure one of the best Bf 109 kits in 1/48 out at the moment. If you have missed my build blog or just want to go through it again you still can check out my
Utti Air Racer with 126 w.i.p. pics, incl. some historical photos ....
.... the painting of this Mersu was mainly done with Vallejo paints 71046 (RLM 76), 71258 (RLM 74) and 71259 (RLM 75). The propeller was painted again in RLM 70 (Revell No. 40), though the blades could also be black. I find it interesting to see that post war Mersu had yellow propeller tips (but only on the front side), while during the war they had not, like on all german aircraft. For painting the spinner spiral I have used the Eduard mask EX500, which makes it easier than the decal. Final coating was again made with Flat Clear Varnish from Marabu. Like MT-230 also MT-508 is build out of box and not weathered ....
.... all decals come again from this great sheet Eduard provides with the kit. It's no problem at all to apply these colourful big decals. It just needs some time and patience. The stencils here are again in finnish language. MT-508 is one of two post war options this kit offers. You can see it by the new white-blue-white roundels as the FiAF national insignia after 1945. Unfortunatly Eduard doesn't offer this limited edition in their online shop anymore. So if you like to build this aircraft also you have to try your luck somewhere else, I'm sorry.
So, again I say "kiitos" for walking around my first racer and I hope you've enjoyed it as I have enjoyed building it.
Happy modelling and take care!
Torsten
