Brian,
That's some agenda you've got for the two of you. Sure hope that you get through all of it. Like you, I hate butt joints, but ended up having to live with it on the Buffalo. Joel
Well, I'm not saying we'll get through it all!
Probably the door openings and the wing spars, with some concept discussion about the crawl-space/tunnel. We will see. I think the wing spar solution will be simple, and actually somewhat elegant. He and I have discussed it. Something like what Monogram did with the B-29 kit.
Whatever we do will be documented.
I did not realize you butt joined the wings on the Buff! Did you pin anything from the wing edges to the fuselage sides? I would have thought that about four pins each top and bottom would add some strength, so that it isn't just the glue holding the wing on, even if the depth of the pins in the plastic wouldn't be that deep.
Brian,
Nope. Just a ton of glue, and I made sure that the surfaces were flush and smooth. The more I think about it, I should have pinned them, but being basically lazy, I just skipped it, and continued on with the build.
