Hi all,
I thought I'd join this campaign! I don't know if my entry will be allowed, since it is even smaller than 1/144 (looks like I'm on a downward slope, eh!
). On the other hand, I'm entering with no less than three subjects in a special "seasons' greetings" diorama. Hopefully, this will be a christmas treat for y'all (especially Jean-Luc).
This is where I'm at right now. As you can (hopefully) see, it is two Polikarov I-16:s and an airfield starter AS-2 (scratch built) on GAZ AAA chassis. The scale is 1/285. In other words, it is small!!!
This is the boxart picture that inspired me.
I've used models from a company called GHQ, who makes models primarilly for wargaming. The detail is awesome for this scale. Here is the Gaz AAA truck that I used as base for my airfield starter. I've just tried some wash and dry-brushing to highlight the details.
I then used streched sprue and plasticard to modify the truck into an AS-2 starter.
The numbers for the aircraft were taken form the fine print from other decal sheets!
I worked pretty hard on these I-16:s to make them nice The red stars from GHQ were pretty bad, so I had to enhance the red with a razor point pen. It bled a little, but I will fix that. Besides, I don't think that will show in the final model... Do you see the globe in the background?!
The pine tree will cover up the water filler hole (and hopefully add a little christmas spirit!). I'm thinking of adding a flag pole with the Soviet flag waiving.
Here is the diorama on the outside...
...and here it is inside the globe! If we all make a wish (and if everything works the way that I hope that it will), I'm pretty sure that snow will fall soon!
Ps. The only issue I have right now is which kind of varnish I am going to use in order to protect the diorama. As you have probably figured out, it is all going to be under water... If you have any suggestions, don't hesitate to post!
Cheers!
