Wow, That was a really neat Sabre!
You just gotta love those colorful birds!
My bird is anything but colorful, It´s BLACK, BIG and MEAN!
After I had completed the outer wing sections I had to fill the seams on the underside.
But as I didn´t want to destroy the fine detail on the wings, I had to use an old trick.
First, filling about 10cm (4") of the seam;
th
Then I used a cotton bud dampend with Acetone(?) to wipe off the excess.
It works fine as long as you don´t use too much Acetone as It can harm the plastic.
Seam filled, and the detail are still there, the miscolouring will dissapear when the model is painted.
Instrument panels fitted to the upper forward fuselage;
The cockpit tub fitted to the lower;
Camera ports painted clear blue and masked off with Tamiya tape;
Now we are ready to join the upper and lower fuselage parts;
Done, and left overnight to dry;
The nose attatched;
...and the second upper fuselage section glued;
Not so many parts, but they are large, so the aircraft is really starting to show It´s sieze!
Then I turned to the aft fuselage section and assembled the wheel wells, upper and lower fuselage.
Amazingly good fit on this old kit!
Some filler will be needed, but not as much as one might expect on such an oldie!
Testor´s really made a good kit!
Soon it will be time to join all fuselage sections!
Cheers!
Stefan E
