Eetu, don't throw away the background (paperboard?) of your workbench... it's a piece of art!
Just newspaper spread over my workbench, taped down. I never thought it could pass as an example of modern abstract art, altough I admit noticing how all the paint smudges, taped over scalpel and all kinds of notes written across make it kind of artistic.
I can send it over when I change it the next I clean up my workbench, if we can come to an agreement on the price!
But on to this campaign entry of mine.
Now I got two 190s at the same stage of construction.
Note the styrene shim on both sides making a nice seam that doesn't require anymore filling at this point. The resin front fuselage piece fit nicely, although getting it to line up nicely required some care, as we see on the next pic -->
The fuselage halves are too close together OOB, so it was either a matter of adding a spreader of some sort inside the fuselage or gluing styrene sheet to make the resin piece spread the fuselage. I went with the latter, because this way the resin piece fit precisely withhardly any (if any at all) sloppiness in the fit, which is always nice when gluing things with CA. When the fuselage front pieces was in place, the wing subassembly lined up nicely with the nose fuselage sides and the resin part itself.
The tan pieces are the exhaust pipes which I made by cutting up and drilling out Academy sherman vehicle tool handles. Here's how they look from the outside.
The solid-moulded cooling gills were also modified by opening them wtih a bare metal panel scriber. I've been puzzled by this tool as it seems to be all too easy to accidentally make a line too wide and deep, so I haven't used for panel lines much. But for these kinds of things it really hits the spots.
Next: taking care of the seams and gluing on the stabilisers.
Stay tuned.
