Hi everyone,
Sorry it's been awhile since I updated my work on the Marauder. Work has gotten in the way I'm afraid
I guess I'm just going to have to look harder for that winning Lotto ticket
Anyway, one of the major reasons Monogram models fell out of favor with most modelers is the raised panel lines. When Hasegawa and other manufacturers perfected in laid panel lines Monogram fell out of grace and a lot of really nice kits disappeared. It was a shame .
The problem with raised panel lines, really, is if you have to sand the model to get rid of seam lines et al. you loose the detail. This is were this trick comes into play.
Usually, you can use tube glue or plastic weld to really soften the plastic, then press the 2 halves together and you get melted glue oozing out of the seam
When the glue drys (about 1 hour for tube glue or 30 seconds for the weld ) you just scrape the bead off and you should be all set
Now, my problem was this
I wound up with one heck of a seam on this thing!
Why? Just being purley nieve
At my age you'd think I'd know better
Anyway, My LHS was out of Tenex 7 Plastic Weld. The guy there tells me that the plastic weld with the orange label is exactly the same thing. Twice the size and cheaper to boot! So I beleived him, he works there after all.
Oops
The probelm is obvious. Putty and sand and loose all the detail. Sand the entire model, putty and sand and rescribe
Not likely
The solution to the problem was something that a friend of mine showed me a few years ago at a meeting of IMPS Nightfighters Chapter of Vero Beach.
What is needed is Tamyia putty, nail polish remover (acetone based) and cotton swabs.
Apply a thin layer of putty over the seam, thick enough to fill the trough, but as thin as possible other wise. I usually work about 2 or 3 inches at a time. After applying the putty wait about 10 to 15 minutes, until it sets up but before it cures.
Sorry about the focus, but it's what you get with a point and shoot camera
Then it's just a matter of wtting the end of the swab with the nail polish remover and wiping off the excess putty
Simple yes?
Stupid camera
Anyway, after rubbing the seam with the pemover for about a minute all the excess putty is gone leaving a smooth seam.
Just continue on, top and bottom. When you are done make sure you wash the model in warm water to get rid of the acetate since paint will not adhere to it
And that's it
Later
