OFFICIAL: Spitfire/Seafire Campaign
MichaelSatin
KitMaker: 3,909 posts
AeroScale: 2,904 posts
Posted: Friday, February 11, 2011 - 08:34 AM UTC
Hi guys! Not that I'm actually DOING anything on any actual Spitfire, but I wanted to dip my oar in on the painting thing. I have a bunch of 1/48 Spits so a while back I used a set of Tamiya painting instructions as a guide and actually cut up a pair of kitchen rubber gloves as paint masks and saved 'em. Now when I do a quarter scale Spitfire, I use rolled up pieces of poster stickum on the edges of the masks when I paint.
I figure that's pretty much how the Brits did it! Except maybe for the poster stuff.
Michael
On the bench:
Ontario, Canada
KitMaker: 270 posts
AeroScale: 264 posts
Posted: Saturday, February 12, 2011 - 01:37 AM UTC
And I've got the last colour down.
Hi mycroft. An excellent job on the camo, bye-the-way.
Looks like you cut the masking tape to suit your camo pattern. I was wondering if you found that easier than using the "rolled-up-sausage" TicTac method used on projects by others. Did you have any issues with the tape lifting paint?
Note I'm working in 1/72, so the blu-tac method is a little problematic for getting good demarcations on the relatively hard separation that the TLS scheme should have. I've used both methods in the past and prefer the cut tape method for 1/72 and the blu-tac method for larger scales where a little softer demarc looks fine.
Tape lifting paint can be an issue, but if you peel at an acute angle and don't use paint with adhesion issues (like MM Acryl) it's usually not a problem. I'm using the Tamiya paints here, the three colours specially released for their 1/32 Spitfire plus their Sky and IJN Interior Green which is a close match to RAF interior green.
California, United States
KitMaker: 4,287 posts
AeroScale: 1,164 posts
Posted: Saturday, February 12, 2011 - 11:07 AM UTC
"Don't fear the night, fear what hunts at night"
MichaelSatin
Posted: Saturday, February 12, 2011 - 12:57 PM UTC
Hold on to your hats everyone, I've made some progress! I present, the interior (or most of it):
Pacific Coast 1/32 Spitfire IXc, the first Israeli Spit.
I also have a theory on the "primer green" color the aircraft was mostly painted. The Avias arrived from Czechoslovakia at about the time the Spit was being rebuilt. What if they used the same green paint (which I've seen described as RAL 6013 Reed green or a late war RLM 83)? I wouldn't be surprised if they got some of the paint from the Czechs too. Seems to make as much sense to me as anything else, we'll run it up the flagpole and see who salutes!
Good job Matt, by the way!
Michael
On the bench:
litespeed
News ReporterEngland - North West, United Kingdom
KitMaker: 1,976 posts
AeroScale: 1,789 posts
Posted: Saturday, February 12, 2011 - 09:51 PM UTC
Nice bit of thinking Michael, I would run with that. Should make an interesting looking Spit. Glad to see you made your mind up about which type to go for. The Pacific Coast MkIX has long been on my list of "to acquire" so I will be really interested to read what you think.
Matt as ever your build looks great, nice one. That's the way I use masks for camouflage. It's one of those ideas that you think, surely the blast from the airbrush will lift the the masks, but it does'nt and always works a treat. Thanks for sharing.
Hoping, no I am going to do some work on my Pr XIX this weekend. I will have it ready for some primer by this evening.
All the best and keep up the excellent work everybody.
tim
litespeed
Posted: Sunday, February 13, 2011 - 12:59 AM UTC
Posted: Sunday, February 13, 2011 - 02:43 AM UTC
Looking good Tim. Keep at it.
Thanks for the kudos Mike and Tim, much appreciated. "Q"
Posted: Sunday, February 13, 2011 - 04:24 AM UTC
Just put the wraps on this with one final mishap. The carpet monster ate my rear view mirror as I was grabbing it with the tweezers...
Oh well, it's done.
Supermarine Spitfire Mk.IIa No. 118 Squadron, "A" Flight, Royal Air Force Ivesley, UK, May 1941 Thanks, "Q"
litespeed
Posted: Sunday, February 13, 2011 - 09:44 AM UTC
Hi all
Nice one Matt, the 'Borough of Lambeth' looks excellent.
I have completed the build of the contra prop for PS 890. It took a lot longer to create than I thought it would. Noticed this afternoon while studying the prop positions of PS 890 at rest, that the aircraft has a three spoke wheels, and the kit only comes with a four. A bit more surgery tomorrow me thinks. I have had to postpone the applying of the primer this evening. Stupid me forgot to fill in the ejected cartridge holes for the machine guns
#041
Kobenhavn, Denmark
KitMaker: 10,069 posts
AeroScale: 3,788 posts
Posted: Monday, February 14, 2011 - 02:48 AM UTC
Beautiful Spitfire, Matt. Love how the camouflage turned out.
I have still not started on my Spit .....yet
Posted: Monday, February 14, 2011 - 09:22 AM UTC
Thanks Jesper. Glad you like it. "Q"
litespeed
Posted: Saturday, February 19, 2011 - 07:28 AM UTC
Hi all
A bit of progress on PS 890 today. Made and glued on various bulges under the wing Attached the props, windscreen and rear part of the canopy. I was not happy with the location of the camera port behind the pilot, so have filled the hole and redrilled the hole. Just glued the flaps to the radiator. Possibly some paint tomorrow, but then again I said that last weekend
All the best.
tim
Ontario, Canada
KitMaker: 270 posts
Posted: Tuesday, February 22, 2011 - 07:02 AM UTC
Matthew: That's one lovely Mk IIa
Tim: Your Seafire's coming along nicely. I have to say that the longer nose/spinner of the FR47 does make the entire aircraft look a lot meaner than the shorter variants.
And here's an update on my Vb, paint's fixed and I'm starting on the decals.
litespeed
Posted: Tuesday, February 22, 2011 - 08:35 AM UTC
Hi Adam, thanks it is coming along. I think thats why I like Griffon powered Spits so much, they just look that more aggressive than the Merlin powered Spit's. I keep finding new photos of PS 890 so I keep tinkering around with it. Discovered there is no evidence of the two lights near the undersuface wingtips as found on the Academy XIV kit. So I have just filled the holes in with sprue. Also the two strips just outboard of the wheel wells that I added, are way too long so they are being trimmed down. I think I am getting to the point where I will be saying to myself thats enough, get on with some painting.
By the way Adam the Spit I am building is a Mk XIX. One of the owners of PS 890 installed a Avro Shackleton Griffon engine and it's contra rotating props when rebuilding it.
I have seen PS 890 several times now, on static and flying displays and I just love it.
All the best.
tim
Ontario, Canada
KitMaker: 270 posts
Posted: Tuesday, February 22, 2011 - 11:17 AM UTC
All the best.
tim
A modified PRXIX with a Shackleton Griffon? what a unique subject PS890 is. I'd made the assumption it was a Seafire just based on the prop.
Oh, and here's the update pic I forgot to put in my last post:
Italieri Spitfire Vb by
mawz_models, on Flickr
litespeed
Posted: Tuesday, February 22, 2011 - 10:56 PM UTC
Looking good Adam, it always feels like a great step forward when applying decals. Nearly there.
All the best.
tim
Posted: Wednesday, February 23, 2011 - 01:12 AM UTC
Nicely done Adam. As Tim said, almost there.
"Q"
Ontario, Canada
KitMaker: 270 posts
Posted: Thursday, February 24, 2011 - 04:19 AM UTC
And we're done. Brief bit of drama at the end as the floor monster ate the aerial, but a cut-down Ju88 aerial from the spares box proved workable as a replacement.
Spitfire MK Vb by
Spitfire MK Vb by
KitMaker: 1,381 posts
AeroScale: 1,110 posts
Posted: Thursday, February 24, 2011 - 05:50 AM UTC
hi all,
a little update,gloss coat on ready for decals.
paul
litespeed
Posted: Thursday, February 24, 2011 - 05:59 AM UTC
Lovely looking Spit Adam, excellent paint work.
Don't forget to place an image or two in the gallery.
Paul your prototype Spit looks great in that gloss blue. Nearly there.
All the best.
tim
Ontario, Canada
KitMaker: 270 posts
Posted: Thursday, February 24, 2011 - 06:13 AM UTC
Paul, that Prototype looks gorgeous, can't wait to see the finished item.
Tim: Thanks, and the pics are in the gallery.
Massachusetts, United States
KitMaker: 137 posts
AeroScale: 28 posts
Posted: Friday, February 25, 2011 - 04:16 AM UTC
...Brief bit of drama at the end as the floor monster ate the aerial...
Hate that. Thought I was the only one that had a hungry floor monster (I work over the rough concrete in the basement of my 100 year old house - impossible to find small parts on), but I guess I'm not alone.
My modelling time has been severely curtailed by a motorcycle accident. I'll do my best to complete the campaigns I have signed up for, but I think a few of them won't be done in time.
MichaelSatin
Posted: Sunday, February 27, 2011 - 03:56 AM UTC
Fuselage buttoned up on my 1/32 Pac. Coast Spit IXc.
Here are a couple of pics of the cockpit:
Working on at least two other campaing aircraft as well, a 1/48 Mirage for Cold War Jets and a 1/48 MiG-21 for Mischeivous MiGs! Oh, a campaigning we will go, a campaigning we will go...
Michael
On the bench:
litespeed
Posted: Sunday, February 27, 2011 - 04:47 AM UTC
Nice Michael, very nice. Does those lovely instruments come with the kit.
All the best.
tim
MichaelSatin
Posted: Sunday, February 27, 2011 - 05:36 AM UTC
All the best.
tim
Tim,
Thanks! Yep, this is completely box stock. Pacific Coast kits use Eduard pre-painted photo etch and as far as I can tell are probably the best instrument panels out there!
Michael
On the bench:
