Hi,
I'm building the cockpit of the Dragon Messerschmitt Bf110C-7 1/32 using an Eduard PE-set, and I have some questions about some PE parts in the rear end of the cockpit.
Eduard suggests that there should be a frame (part #52) containing a radio (or something) below the spare ammo drums, and also a plate or deck (#53) with a box (#72) on top of the side walls (ie above the ammo drums). Please see attached images.
I have not been able to verify anywhere, that these parts were actually fitted on bf110C, either on other kits or original photos (I have checked the instructions for Eduard bf110 1/48 - they are not there). Does anyone have a picture that shows these parts mounted on a real bf110 or a plastic kit?
Also, I am sure that the position of the plate #53 is wrong, because it will be completely hidden by plastic part A4 (part of the fuselage). And also because plastic part E15 (a big frame) would not fit at all. Maybe the correct position would be right above #52, ie. below the spare ammo-drums.
Eduard mentions that they used the following 2 books for references: "Walk Around #24 Messerschmitt Bf 110" and "Aero Detail Messerschmitt bf 110". I have checked both of those books, and I cannot find any picture of the items in question
Some expert suggestions are badly needed!
Kenneth
