OFFICIAL: Small is Beautiful Campaign
New South Wales, Australia
KitMaker: 179 posts
AeroScale: 170 posts
Posted: Sunday, January 22, 2012 - 11:10 PM UTC
Here are two pictures of my Zveno with the parasite fighters built and the TB-3 basics done all ready for painting.
The Dornier is built and has had the Undersurface colour (RLM65) and the top surface base colour (RLM63) sprayed on.
regards
Peter
Regards
Peter
Mudgee
Australia
#259
Massachusetts, United States
KitMaker: 2,265 posts
AeroScale: 1,715 posts
Posted: Monday, January 23, 2012 - 12:40 AM UTC
unbelievably cool.
I gotta have me one of those !!
#259
Posted: Monday, January 23, 2012 - 07:31 AM UTC
KitMaker: 1,381 posts
AeroScale: 1,110 posts
Posted: Friday, January 27, 2012 - 03:17 AM UTC
peter that looks fantastic, will look great painted.
paul
Posted: Friday, January 27, 2012 - 03:19 AM UTC
my little update...
the hurricane is getting painted! camo this weekend hopefully.
paul
Ohio, United States
KitMaker: 258 posts
AeroScale: 2 posts
Posted: Friday, January 27, 2012 - 01:00 PM UTC
Small update: Major assemblies are done. As you can tell I had to use masking tape to keep the wings in place while the glue is drying. Fit is pretty good so far, but will still need to sand down some seams.
KitMaker: 179 posts
Posted: Saturday, January 28, 2012 - 10:55 PM UTC
Well my first model is done and in the gallery!
The Dornier 17E is finished see below for 2 photos and the TB-3 Zveno has all planes completed and the upper Green Camo sprayed on all planes.
Regards
Peter
Mudgee
Australia
Ontario, Canada
KitMaker: 470 posts
AeroScale: 99 posts
Posted: Monday, January 30, 2012 - 06:19 AM UTC
Here is mine. Not quite up to my ususal standard as I made a mistake. I built and painted it like I do my usual 1/72 planes. But its not 1/72 and some stuff worked less effectively than I expected. Learned a couple of new things though. Its in New Zealand colours and I heavily weathered it.
KitMaker: 394 posts
AeroScale: 360 posts
Posted: Monday, January 30, 2012 - 11:24 AM UTC
So, I had joined up in here a little while back. This is what I'm going to attempt to build:
Just because the parts count is a little weak, I'm not entirely convinced it will be any easier:
The resin castings are beautifully done, although do suffer from the heavy panel line syndrome:
I'll choose the RCN decal offering, but don't really have high hopes with reguards to their quality. If AM decals are required, I'm hoping CanMilAir with come to the rescue.
I'll be starting this tiny project today, and will report back when there is progress.
Current Projects: 1/144 R5D-3 (MiniCraft)
1/48 Ford Flivver (Williams Bro.)
1/72 UC-64A Norseman (MatchBox)
MAAC No.51187
IPMS CANADA No. 3369
#259
Posted: Monday, January 30, 2012 - 12:12 PM UTC
Miniwing is God tier planes! that's a nice choice.
you've got that right, parts count has nothing to do with the challenge of 144th !
I like the YKraft/Miniwing decals. You do have to do alot of cutting, but the film is very thin and responds well to Micro-Sol.
British Columbia, Canada
Posted: Monday, January 30, 2012 - 01:44 PM UTC
CanMilAir will definitely come to the rescue. Bill does
4 different schemes for VF870 and 871, and whatever scale you want.
-Leonardo Da Vinci
KitMaker: 394 posts
Posted: Monday, January 30, 2012 - 07:08 PM UTC
Thanks, Jessie. I odered a set up this very evening, along with those of the Tracker, Caribou, Catalina, Harvard, and F-104 x 2. All in 1/144.
MAAC No.51187
Posted: Monday, January 30, 2012 - 09:29 PM UTC
what great and diverse kits we have in this GB.
pbhawkin, a lovely little kit and i really like the camo scheme.
611_sqd, really like the colours, would make a great subject in 1/48, i'm also having to rethink how i do things in this scale as the smallest i've ever done before is 1/72.
mtnflyer, i've never seen that kit before but the resin looks good.
and its not easier to build these kits just because there are not as many parts!
keep up the good work everyone
paul
KitMaker: 394 posts
Posted: Tuesday, January 31, 2012 - 07:01 AM UTC
Using my favorite razor saw, I carefully cut the resin from its casting blocks. Then even more carefully sanded the parts to fit with various sanding stick, pad, and pencil:
Even as nice as the Miniwing castings are, there still remains some required repair issues. I think this one is particularily hurtful.
This happens to be the right wing forward root just at the engine intake. Looks to me to be a painful fix, and I'm considering if I should effect the repair with wing off, or attach it to the fuselage first?
It only looks like an easy repair if it were not for its small size.
The very easy required fixes are shown here:
Hmmm! I'll have to work at this some.
MAAC No.51187
Posted: Tuesday, January 31, 2012 - 07:23 AM UTC
Superglue slivers of paper inside the intake, then build up epoxy putty on the outside to fill the holes. The paper should be thin enough to not fill in the intake too much, and will make the inside of the intake a uniform surface. Once everything's dry you can sand it to shape, especially when you've done some preliminary scuplting while the putty is still wet.
-Leonardo Da Vinci
KitMaker: 394 posts
Posted: Tuesday, January 31, 2012 - 07:40 AM UTC
I'm not sure how you always seem to have the answers Jessie, but you most certainly do! I read it three times to set it in my noggin and will now put your outstanding solution to good use. Thanks.
MAAC No.51187
California, United States
KitMaker: 30 posts
AeroScale: 28 posts
Posted: Tuesday, January 31, 2012 - 07:57 PM UTC
Hi folks, I'm in with this
KitMaker: 107 posts
AeroScale: 16 posts
Posted: Wednesday, February 01, 2012 - 09:24 AM UTC
Hi Folks,
My entry for this campaign will be a Harrier GR3 by Revell.
Never done anything as small as this before so I hope my eyesight and clumsy hands will cope.
Keith
The biggest room in the world is the room for improvement.
#259
Posted: Thursday, February 02, 2012 - 01:56 AM UTC
I cant work on little stuff with less than 3.5X magnification.
ordinary reading glasses from CVS work fine, but
I love my Optivisor.
Georgia, United States
KitMaker: 331 posts
AeroScale: 135 posts
Posted: Thursday, February 02, 2012 - 03:08 AM UTC
While rummaging around AeroScale and my model pile I pulled out a DML 1/144 EA-6B kit for this GB. More to come soon.
Support your Local Hobby Store.
Still boycotting Dragon Sytrene tracks. Ick-poo!
Current project:
Looking for my mind, I lost it somewhere.
KitMaker: 179 posts
Posted: Friday, February 03, 2012 - 03:00 PM UTC
Here is the TB-3 'beast' with the top surfaces done in AII Green (done in the now unfortunetly closed JPS acrylic paints) and masked ready for the AII grey-blue undersides:
regards
Peter
Regards
Peter
Mudgee
Australia
United States
KitMaker: 288 posts
AeroScale: 195 posts
Posted: Saturday, February 04, 2012 - 02:45 PM UTC
Well, I have not been able to do any modeling since early January due to some major repairs being done on my house. The contractors finished up what they had to do in my model room, and I got it back this week. Yay! To celebrate, I started back on the F-15J and managed to finish up painting the cockpit. Here is how it now looks:
It is not a perfect fit but I think this will look the part. It sure is a big improvement over the solid cockpit area in the original kit!
Have fun model;ing!
Mike
KitMaker: 4,728 posts
AeroScale: 1,351 posts
Posted: Saturday, February 04, 2012 - 11:20 PM UTC
I'll not bore you with a photo as all I have done is applied prime to the parts while still on the sprue, first step for my Me-262A.
I'm at a show next weekend so that will see the first parts put together, my bench should be cleared off of other projects shortly.
On the bench...
Italeri A129 Mangusta
British Bulldog Spitfire theme build
Stockholm, Sweden
KitMaker: 1,953 posts
AeroScale: 1,902 posts
Posted: Monday, February 06, 2012 - 08:42 AM UTC
I am nearing completion now! Final assembly is a lot trickier than I expected, all the mating surfaces are terribly small making glueing difficult.
More about it in the
build blog.
Magnus
Press banner to the right to follow my trail to the new forums!
#047
KitMaker: 2,016 posts
AeroScale: 475 posts
Posted: Tuesday, February 07, 2012 - 01:06 AM UTC
Hi all
I'm going to do this bad boy
my favorite markings VF 111 the sundowners
more pics soon as I've just found my lead from camera to pc
Andy
Major Caryle,
"Shall we have a go at the far end now,sir?"
Lt Colonel "Johnny" Frost,
"Having a go,is hardly text book terminology Harry"
Major Caryle,
"But you'll let us try sir?"
A Bridge Too Far
Lottery Campaign "Oh de Vichy"
