I applied liquid mask using a piece of scouring pad, in strategic places and I used Mr Paint to paint the white areas.
Perfect work, Mal, great presentation.
Yes, you are rockin' those stripes! Good idea on the liquid masking- I'm looking forward to seeing some wear and tear.
Mal,
without a doubt, you're the master of Masking. It's looking real good. Now bring on the paint.
Nice tips.
Mal,
Nicely done. I like your method much better then the convoluted method I try to use with thin strips of masking tape.
Mal,
Mal,
I never thought of that. I just figured if the dia of the hole was correct, as you moved the piece of plastic down the bomb, it should be easy enough by eye to square up. That assumption doesn't seem to be quite true.
Quite a brilliant way to paint those warheads, Mal- cheers!
If you can mount the missile vertically plums, you can level off the card mask in a couple of stacks of books flanking it. Hmm- that would work for spinners as well! Gotta try that one out now. The Hawker is lookin' mighty fine!
Great paintwork! Loooks absolutely outstanding!
Nice tip on painting the missile tips.
Looking forward to see more
Mal,
That's certainly a excellent way of mass producing those bomb stripes accurately, and neatly. Well done.
