Hi all, I must say I am really impressed with the builds coming out of this campaign, I especially admire Bryan's Swordfish.
Well after some rescribing of panel lines on my Bv138, which include filling some after slipping several times with the scribing tool (Olfa 'P' cutter). Also adding some silver foil for some raised detail on upper fuselage fairing & nose. I proceeded to prime the beast. After drying any defects were resolved.
I then gave it a second coat which gave me a satisfactory finish. Masking was next on list, using the spare canopy,as a template & Tamiya masking tape I proceeded to make the canopy masking. Turret masking was done in the usual way strips & then filling in clear areas with offcuts of tape.
She's now starting to look more like a Bv138!
I've added pitot tube from a hypodermic needle, drilled out holes for lights in bow. I sanded down the front of each wing mounted engine nacelle leaving a thin rim around the openings, as looking at photos this gives a more accurate representation of the original. Holes drilled for exhausts, when I can find tubing of the right diameter to make them.
Now comes the difficult part choosing which aircraft to model, camouflage isn't a problem except for winter camouflage or not
With time running out for this campaign I guess I'd better make my mind up a.s.a.p. Certainly not enough time for diorama or beaching trolley as was my original intention
That's all for now look forward to seeing all the completed builds.
Cheers Andy
