Nice to see that you got the wing issue shorted out . Also , very fine job on the tail section
Terri
Hey Joel ,
Nice to see that you got the wing issue shorted out . Also , very fine job on the tail section![]()
Terri
Nice progress again! Good to see you got the wing problem sorted out. I see you've still to glue in the fuselage belly window. Looks like it would be quite tricky to attach at this point with the majority of the cockpit components in place. Or are there some sort of ledges to stop the window from falling in?
Anyway, looking forward to seeing this come together.
Btw, I've made a start on that 1:48 scale Classic Airframes B-239 I mentioned a while ago. I'll start a build thread for it as soon as I get some WIP pictures taken.
Fascinating - I keep away for a few days and then here's suddenly an almost completed Buffalo to look at! Well done with the wings!
Magnus
Tough build Joel! I'll stick with the 1/48 Buffs.
Looking good Joel, you have handled the issues well.
Hi Joel,
Nice save on the wings.
Now that Eetu has started a buffalo kinda reminds me of a TV ad that played here a while back (paraphrased)
Nice flock of Buffaloes
Herd of Buffalo
Yes I have,heard of chickens.
Chris
Man, I had no idea this kit was such a challenge. Like I said, I'll stick with 1/48.
Coming along nicely.![]()
Usually recommend pinning the wing joints, but since the cockpit is in the way for most of the way, it looks it looks like it would be possible to do only for the front part of the joint.
But at least the joints are flat, that should reduce the challenge to "only" getting the hidedral right and making a sturdy enough joint.
Very nicely done Joel
Hmm, if those gaps are wide enough, I'd rather shim them with thin styrene sheet than use putty, which merely fills without providing structural strength to the seam.
