Micheal: Sorry for that issue with the engines, they're really worth to show! But you know they are there...
So even all is closed up this bird will look great. Awaiting your next step.
Some updates from my Hudson:
First: A short overview of the kit. It's MPM's molding and reboxed again from both Revell and Italeri. Both manufacturers have the same sprues inside, just different decal options. So you can build either a Mk. I/II or Italeris Mk. IV/V by just adding/changing some parts (i.e. the exhausts, engines, antennas). Both you can show with a seperate sidedoor opened after cutting the fuselage.
I decided to leave mine closed and I have to take the two "half-molded on a plate" Wright GR-1820-G102A Cylone instead the later Twin-P&W R-1830-SC34G (molded in two seperate parts each; nice for the spare box).
Second: The fit - didn't checked the wing/engines and wing/fuselage connection yet. But the the turret section needs help as well as the cockpit/nose part (well known problem of this kit and mentioned as well in the instructions to obtain a good fit). Overall the fit isn's bad!
Clear parts also not yet cleaned or dry fitted - so lets see later how they will go.
Meanwhile a step further with the build - first paint shop and some shades of green... and a few black parts
First color on, Tamiya flat black and Revell Aqua 360 farn green
Thomas
