Will be working on the window fix next, but I need to order some clear acetate sheet.
Hey Joel, is this the stuff I pointed out in the after fuselage?
Brian,
Yes.
I'm looking at trying some of the clean acetate from packaging. I've also thought that once the fuselage halves are closed up, there is next to no light in the areas of those windows, so basically all you'll see is glossy black, especially at a distance of a foot or so as a display model. so what if I painted white sheet plastic black, then after the model is completed I use Microscale Krystal Kleer to make the glass. The effect should be the same as looking through the other windows with clear plastic inserts. Besides, the clear acetate will still need a coating of Krystal Kleer to bring it up to the level of the fuselage skin.
