This week I finally started the painting process. The bottom of the B-25B was painted with Lifecolor Neutral Gray #43 fs36173. I thinned the paint with LifeColor's own paint thinner rather then with my usual Tamiya X-20A.
After quite a bit of experimentation with LifeColor paints, I settled on a basic thinning ratio of 4 parts paint to 1 part thinner, air brushed @ a flow rate of 16 psi.
The Olive Drab top coat is a going to be a 3 part process. The basic color is LifeColor Olive Drab #41 fs34088, thinned and air brushed with the above specs.
Using Silly Putty for worms to aid in painting a somewhat soft edge demarcation line, and then filling in the rest of the space with detacked Tamiya tape. The paint was applied in 3 light coats for the bottom, and 6 very light coats for the top.
I didn't have any clogging issues with the Gray coat, but the O.D. coat constantly clogged my Iwata M2 AB with a .35 needle and cone. Go figure.
These pictures show the two base coats. In a day or so the next top color will be LifeColor's O.D. #41 weathered for a slightly faded blotchy effect, then a final sporatic blotchy coat of #43 with a few drops of Flat Black.
The Silly putty for the `1st time left a oily film when I removed it. I tested a damp Qtip with tape water, and it comes right off. I still have some areas to do, which is the darker areas you'll see in some spots by the demarcation line.
I'm really quite happy with the base O.D. color for a change, and didn't have to tint it as I always have to do with the Tamiya Acrylic O.D. paint.
