Work is well underway on my Tracker. There are quite a few corners that have been cut with this kit in terms of detail but hopefully I can turn it into something decent.
The cockpit is quite basic and rather dark once it's all closed up so it just got a quick and dirty paint job.
The instructions call for 50g of weight in the nose cap to prevent tail sitting but there is not nearly enough space in the nose for that much weight, so I started cramming lead sinkers wherever I could hide them, mostly under the cockpit floor around the nose gear bay, with a few behind the rear cockpit wall and even some bits inside the pilots seats and behind the instrument panel.
Even the engine got some weights
One challenge came with painting the deployable radome, as it's partially obscured. First problem was the hole was not large enough to fit it deployed, so careful sanding and test fitting got the hole fractionally larger than the radome. Then I painted it before assembly and covered it with stretchy masking film as that should be removable without leaving a residue once the fuselage is finished. Something that's apparent, even installed in the "deployed" position it still doesn't look like it extends far enough compared to photos of the real thing.
Since shelf space is at a premium I decided to go with the wings folded option, and while not perfect there is some detail provided for the wing fold mechanism.
The wing mounted search light really stands out with its total absence of detail as it is just a flat panel with a clear dome over it. So this got some attention, first I dremeled it out to give it some depth
and using a domed head bolt, silicone putty, and a household iron I created a plastic dish for use as a reflector,
and the whole area was painted black to hide the crimes. The reflector will get a chrome silver coat once everything else is finished.
I would have liked to to leave the munitions bay open but there was zero detail in there and the torpedos are pretty lacking as well, so I sealed it up.
Currently in the process of adding the little detail pieces, and primer should go on soon.
