Well some progress on the F-4J.
I did some more cutting and glueing after that, to make the landing gear extended.
I gave up the idea of the resin cockpit and safe it for a later build. Instead I purchased a pilot set for the cockpit. Will use the resin as a 'master' to copy details that might be visible through the canopies, which will be a minimum.
Previous cut of the landing gear, ready for assembly.
And all glued in extended position
Working on the gear bays now. See if I can add a little more detail. Most of it will be hidden though For the cockpit I have some spares, both resin and PE.
The Academy kit is pretty straight forward, so once these details for a landing AC are finished, it will be pretty much done.
Big challenge to come for the wing, I have to alter the inner flaps in to landing position, means all the way down.
To be continued.
