What's our starting date.
Looking at the campaign page, it says August 01.
Btw, I don't know if have I paid proper attention or what, but I had this impression that the starting date was earlier some time ago?
If I hadn't checked the campaigns page, I would have probably started building my first entry.
Guess what, a new camera has arrived! My mom bought a new one when our second unit broke in mysterious conditions while being borrowed my my sister ("it just broke" I suspect it got accidentally dropped...).
Well, here's a few test shots I took of the Buffalo mk.I I'm going to build.
Looking at the kit, I can't help comparing it to the Hasegawa brewster first released in the 90's. Indeed, it seems to be "inspired" by the Hasegawa kits, with several upgrades, the most prominent being the gorgeous resin cockpit. (except for the missing seat belts. There's no PE provided either) You can guess where the engine and wheels come from too. The latter have barely visible filled ejector pin marks quite similar to the Hase's styrene parts and the engine also looks similar, with some added details.
The plastic parts also look familiar, but with many changes for the B-339 version. Clear parts appear to be direct copies of the hasegawa, although they aren't as crystal clear as the originals. A dip in future should fix that though. Since the parts aren't modified, they lack the clear vision panel in the left side of the sliding part. No gunsight is provided either.
One modification that I can't understand is the removal of one landing light under the wing. Hasegawa's early brewster kits had them in both wings, so one had to be filled for the early versions. Now this kit has one light, while these later variants had two...
It would be awesome if this meant kits of the early models coming, but from what I've, they're not planning to do them. Also, the main landing gear is now in two parts, requiring careful gluing (but I'll probably drill holes and insert a metal pin to make it more robust).
Decals appear to be of the high quality common to special hobby kits.
Now if this truly is based on the hasegawa kit, it should go together nicely.
