Hi all!
Wow, those Chinook movies were a real treat!
The Italeri Chinook looks like a really good and well detailed kit!
Jesper, If you want a Colorful Chinook, take a look at the US coast guard´s machines!
Red, white and black!
I´m getting into a Chinook mode too now...
My N9-M is progressing rapidly.
Chuck, Thanks for the info!
I found quite a lot abot Northrops´flying wings in "Wings of Fame" vol2 and in a recently Issue of Aeroplane, and lots of pics.
As you said the N-9MB was not a two-seater from the beginning, but a passenger seat was installed, even Jack Northrop himself got a ride in his flying wing!
And that was the fourth aircraft with the yellow on top/blue under scheme, the same machine that are now restored and still flying!
Now to my build;
Cockpit parts painted;
Floor and side walls were made of wood;
The (VERY SMALL) instrument panel was painted gloss black, then I used some of Mike Grant´s excellent instrument decals.
Finally, I sealed the panel with a flat clear.
The small cockpit assembled;
I decided to make the wing as seperate upper and lower parts, to get a better fit and easier alignment.
Now you can get the sieze of the thing, It´s quite a large aircraft!
Even tough this is a short run kit, fit has been almost perfect, with no need for any filler so far!
More pics to follow...
Cheers!
Stefan E
