Hi all!
This is the kit I have chosen for this Campaign!
It’s the Trumpeter kit, but I will add some small “thingies”, as follows;
New decals from Warbird, and one Mustang I have wanted to do for quite a time now; a red-tailed Little Friend from the “Tuskagee Airmen”!
I have chosen to do “Ina the Macon Belle”, aircraft no.72, 332nd FG, Red tail, spinner and wingtips, with yellow wingbands and yellow/red striped noseband.
Trumpeter’s cockpit is quite good, but wrong for a –B, It’s more of a mix between a –B and a –D model.
So I got an Aires B-pit;
The wheel wells are wrong, as they are on every mustang model out there.
The wells do not follow the shape of the hatches, and ends at the edges, but extends all the way to the wing spar!
With this one-piece set from Aires, You’ll get the correct shape!
I always use Eduard’s etch on every build in the larger scale (1/32), this will not be an exception;
I loathe those rubber tires Trumpeter supplies, so I got a new set from Mastercasters, cheap and wonderfully detailed, and just enough weighted!
Let’s Saddle up!
Cheers!
Stefan E
