Official Sea Plane Campaign Thread
Florida, United States
KitMaker: 2,798 posts
AeroScale: 2,443 posts
Posted: Saturday, December 05, 2009 - 12:25 AM UTC
Jim amazing job re-riviting and re-scribing turned out really strait what did you usr on the curved parts to keep your lines strait?
Build On,
Justin
"From time to time, the tree of liberty must be watered with the blood of
tyrants and patriots."
- Thomas Jefferson
IPMS#47611
Illinois, United States
KitMaker: 3,289 posts
AeroScale: 289 posts
Posted: Saturday, December 05, 2009 - 03:45 AM UTC
@D
Thank you sir.
@Dragon
I use Promodler wash on my models and thank you sir.
Build On,
Justin
Looking closer{nose on the monitor-hahaha} it looks as though you reriveted..my kit is buried or I'd check it.
-I say I have two kids- one son & one daughter...my wife says she has three- one son ,one daughter and one husband.
...and don't tell yourself you can't do it....it'll just take longer then
Posted: Saturday, December 05, 2009 - 11:13 AM UTC
No sir thats how good this kit is all the details are crisp and clean little flash on some of the panel lines on the sides but no big deal.you should un bury it.It is a really enjoyable build.
Build On,
Justin
- Thomas Jefferson
IPMS#47611
Ontario, Canada
KitMaker: 1,505 posts
AeroScale: 595 posts
Posted: Sunday, December 06, 2009 - 03:09 AM UTC
Thank you Justin about noticing the rivets. I made a template out of a beer can, and taped it to the model before scribing using solid masking tape. Very easy and straight as an arrow.
Projects:
K44 Anti Tank gun
Diana
Albatros DIII
Posted: Sunday, December 06, 2009 - 03:21 AM UTC
I will have to remember that thanks Jim.
Build On,
Justin
- Thomas Jefferson
IPMS#47611
California, United States
KitMaker: 4,287 posts
AeroScale: 1,164 posts
Posted: Sunday, December 06, 2009 - 04:01 AM UTC
An update on my seaplane entry, the venerable HU-16 Albatross. I sanded off all the rivets, filled the main wheel wells with Aves Epoxy putty and set the gear doors in the putty to dry/cure. Did the same thing with the remaining gear doors as this is going to be built wheels up flying over some downed pilots. I decided to go this route as the kit had the toy like features of operating landing gear and you could look clean through the fuselage from stem to stern. The cockpit detail consisted of a floor with two seated pilots. Thats it. I plan on painting the cockpit windows black on the inside, and filling all the other window openings with Krystal Kleer tined with some blue coloring.
These are the markings it will be painted in. Gotta love all those antenna's!
And this is where she sits currently. I need to go back over her and rivet some areas that I lost my recessed rivet detail on when sanding. Still a ways to go, but she is taking shape. The silver plastic makes it really easy when adding recessed details. It provides a nice map/guide.
And here is the base it will be perched on. I plan on having it winged over slightly as if the pilot is getting a better look at the downed pilots. Thanks for looking, "Q"
"Don't fear the night, fear what hunts at night"
Ontario, Canada
Posted: Sunday, December 06, 2009 - 06:09 AM UTC
Looking good Matthew!..I was hoping to see some water bases in this campaign!
can you tell us how you did your water?
Did you re scribe and rivet your entire airframe?
Projects:
K44 Anti Tank gun
Diana
Albatros DIII
Posted: Sunday, December 06, 2009 - 06:26 AM UTC
Thanks for the kudos Jim. The base is bass wood. I used 5 min epoxy to glue the kit supplied water/raft to the base before hand. I mixed up a healthy dose of Aves Epoxy putty and applied it to the base after having scored the base to help it stick. I rolled out a couple of "worms" and laid them down to create the waves. Then took a blunt stick and began pushing it into the putty to create all the dimples. Did this several times until I got the choppy look I was wanting. I smoothed things over with wetted fingers then set it aside to dry overnight while I worked on some other campaign entries. I will probably add some Liquitex clear sculpting medium to it once I get around to the base again. Should help impart more of a water look to it. There really aren't any panel lines to speak of on this thing. Just a few and they were already recessed. The rivets on the other hand completely covered the airframe. It was a simple matter of sanding all of them off, smoothing out the sanding marks, then using a rivet roller to replace them. Once I finish up the sanding and riveting, I will polish out everything for a nice smooth canvas for the paint. Hopefully I can concentrate on this thing fully after finishing up my ecology final tomorrow morning. Thanks again for the the kudos. "Q"
Ontario, Canada
Posted: Sunday, December 06, 2009 - 11:27 AM UTC
If anyone is looking for a great thread for trying water effects, go to the Model Shipwrights partner site here, and cherck the campaign "divine waterline"...theres some REALLY good tecniques being explained there
Projects:
K44 Anti Tank gun
Diana
Albatros DIII
#360
Connecticut, United States
KitMaker: 1,020 posts
AeroScale: 125 posts
Posted: Monday, December 07, 2009 - 09:14 AM UTC
Great looking Cat, Justin.
Andrew's Pete is just gorgeous so to do something different, instead of doing up my Tamiya Pete (and avoid inviting comparisons), I'll do my Nichimo E13 'Jake'.
"I wish to have no Connection with any Ship that does not Sail fast for I intend to go in harm's way." - John Paul Jones
Ontario, Canada
Posted: Monday, December 07, 2009 - 12:14 PM UTC
Oh,very good choice, Micheal!!
Thats a great kit and looks awesome when its given the right touch!
I have a 1:72 hasegawa JAKE I plan on doing up later in the campaign, if I can get the Stranraer done in time..
Projects:
K44 Anti Tank gun
Diana
Albatros DIII
Posted: Monday, December 07, 2009 - 03:08 PM UTC
Thank you 7.
You guys need to check out my campaign also PIN-UPS campaign.
Its under nose art campaign right now.
Build on,
Justin
- Thomas Jefferson
IPMS#47611
Scotland, United Kingdom
KitMaker: 1,699 posts
AeroScale: 1,384 posts
Posted: Monday, December 07, 2009 - 08:43 PM UTC
With this talk of rescribing. I've done one half of the sunderland.
Although I'm not sure I've done the right thing. Panel lines dont really show at all on this.
This looks like it would be better served just masking panels. I think I'll need to experiment a little with some butter tubs or something.
Ontario, Canada
Posted: Tuesday, December 08, 2009 - 01:59 AM UTC
interesting point JP ....they talk of " the mad trencher" in reference to the matchbox kits, but have we as modellers fallen victim to fashion regarding panel lines?..hhmmnn
Projects:
K44 Anti Tank gun
Diana
Albatros DIII
Posted: Tuesday, December 08, 2009 - 02:14 AM UTC
Yeah but is there not something therapeutic about carving those lovely straight lines
Ontario, Canada
Posted: Tuesday, December 08, 2009 - 03:43 AM UTC
something like that yes ..lol
Projects:
K44 Anti Tank gun
Diana
Albatros DIII
Posted: Tuesday, December 08, 2009 - 10:22 AM UTC
Had a great deal of bother drawing the codes for G-AGES. until I found some RAF fonts on the web.
Easy then. they aren't quite right. the E was too wide but that is easy fixed. Don't know I never thought of that before. Should have patterns made for masks soon. Just waiting on the props and canopy and I'll be all set to go.
Ontario, Canada
Posted: Wednesday, December 09, 2009 - 02:37 AM UTC
ive realized Im going to have to make new props for my Stranny....They used a pressed and bent prop....It had didstinct bends visible at the center ...the kit ones are inaccurate...go figger..
Projects:
K44 Anti Tank gun
Diana
Albatros DIII
Posted: Wednesday, December 09, 2009 - 06:58 AM UTC
Aint AMS a blast! what's the odds no-one ever mentions the props since it is the thing you noticed
Ontario, Canada
Posted: Wednesday, December 09, 2009 - 07:35 AM UTC
LOL!!!
Projects:
K44 Anti Tank gun
Diana
Albatros DIII
AussieReg
Associate Editor
#007
Victoria, Australia
KitMaker: 8,156 posts
AeroScale: 3,756 posts
Posted: Wednesday, December 09, 2009 - 08:55 AM UTC
Since we already have a BV138 on the go for this campaign I am going to change plans and drag an oldie out of the stash and do a Matchbox He 115, one of the old 3 colour jobbies. Wish me luck.
Now, to do the German or Finnish markings ?? Hmmmmmm
ON the bench
Monogram 1/24 '57 Chevy Nomad
Texas, United States
KitMaker: 1,954 posts
AeroScale: 1,163 posts
Posted: Wednesday, December 09, 2009 - 09:21 AM UTC
Posting an update of my build finally.
I am doing the 1/48 Tamiya Kawanishi N1K1 Kyofu Type 11.
basic construction is more or less complete. Need to finish cleaning up some seams and get the canopy on and masked before priming.
Hopefully I can manage to finish her the rest of the way sometime int the next 9.5 months!
AussieReg
Associate Editor
#007
Victoria, Australia
Posted: Wednesday, December 09, 2009 - 09:48 AM UTC
ON the bench
Ontario, Canada
Posted: Wednesday, December 09, 2009 - 11:30 AM UTC
@Vance ...good looking plane that
@ Damian..good luck with her!
Projects:
K44 Anti Tank gun
Diana
Albatros DIII
North Carolina, United States
KitMaker: 347 posts
AeroScale: 179 posts
Posted: Wednesday, December 16, 2009 - 01:48 AM UTC
On the workbench:
1/48 Spitfire Mk V & Mk VIII (Spitfire Campaign)
1/72 Challenger II (British Armor Campaign)
1/48 AH-64D Apache (CAS)
