Lone Star 1:48 RAF FE 8 vac
Arizona, United States
Posted: Friday, June 11, 2010 - 07:31 AM UTC
I gotta tell ya Terri: Your attention to detail is fantastic. Scratch building the wings, the interior, just top quality work Terri. I am looking forward to more.
Best
We few, we happy few........
Thessaloniki, Greece / Ελλάδα
KitMaker: 90 posts
AeroScale: 89 posts
Posted: Friday, June 11, 2010 - 07:32 AM UTC
Wow excellent and full detailed work you have done here Terri.
congratulations i cant wait to see more.
http://www.facebook.com/pages/Agioplanes/353328611448659
Västra Götaland, Sweden
Posted: Friday, June 11, 2010 - 10:17 PM UTC
Terri – Your attention to detail is fantastic on the interior – almost a shame to close the fuselage up!
Looking forward to more installments on this build.
Best Regards
Posted: Wednesday, June 16, 2010 - 05:26 AM UTC
Posted: Thursday, June 17, 2010 - 08:11 PM UTC
Hi Terri,
Looking really great – I can't get over how good your wings look, really impressive
North Carolina, United States
KitMaker: 604 posts
AeroScale: 600 posts
Posted: Friday, June 18, 2010 - 11:32 AM UTC
Hi Terri,
I have to agree, look better now than before, and they were great then!
RAGIII
Posted: Saturday, June 19, 2010 - 08:04 AM UTC
Thank-you very muck for the kind words Guy's .
I'm almost done with the details on the fuselage and the fin/rudder . I'll have pic's up later today or some time tomorrow once there is enough blood to match the coffee in-take
KitMaker: 90 posts
AeroScale: 89 posts
Posted: Saturday, June 19, 2010 - 09:43 AM UTC
Hi Terri,
i have to agree too, really great work Terri, please keep on rocking.
Posted: Sunday, June 20, 2010 - 12:57 PM UTC
Posted: Monday, June 21, 2010 - 07:26 PM UTC
Posted: Tuesday, June 22, 2010 - 12:50 AM UTC
Terri – this build just keep getting better and better
Best Regards
Posted: Tuesday, June 22, 2010 - 03:24 AM UTC
Best Regards
Thank-you so much Mikael . I'm glad a few of you folks are enjoying this build just as much as I'm .
KitMaker: 1,667 posts
AeroScale: 1,551 posts
Posted: Tuesday, June 22, 2010 - 07:43 AM UTC
Exquisite Ms Werner... nothing more to say
United Kingdom
KitMaker: 74 posts
AeroScale: 71 posts
Posted: Tuesday, June 22, 2010 - 07:46 AM UTC
More than a few.
Posted: Tuesday, June 22, 2010 - 11:15 AM UTC
Thanks for the kind comments guy's , very much apperciated !
Another small up-date .......
Landing struts are done and the wing struts . For the landing struts these were made with alum tubing with a fine steel wire and flatten in a vice with sanding to shape the ends . Wing struts are done the same way , but using brass instead .
Next comes the tail booms !
More to follow soon on a web site near you
Posted: Wednesday, June 23, 2010 - 03:17 AM UTC
I was able to get one of the tail booms done after spending over 4 hours on it . One more to go .......
So far I have found this to be the most frustrating part of the build so far . It did take a few attempts in the end I had to op for plastic rod . I do have brass rod which I found hinden away , but wasn't able to drill into it . So I'm hoping once the are installed and the rigging done they will be able to support the weight of the model over time and not start to sage or bow into some weird shape . The model is light , but the white metal engine does have weight to it .
Posted: Thursday, June 24, 2010 - 05:42 PM UTC
I got one of the tail booms on the finished side . few more small details here and there and she's good to go . Still have another one to make up . but here is the one so far .
The center strut is alum rod with steel wire inside flatten in a vice and a bit of sanding to get it thinner and a bit of shape as well .
Posted: Friday, June 25, 2010 - 05:10 AM UTC
Wonders if you had clamped the brass rod in a small clamp/vice along with some softer material like plastic to drill through first and as a guide as the bit entered the rod might have helped?
As for weight though, A carefully places trestle or groundcrew could act as an extra support Terri?
Posted: Friday, June 25, 2010 - 11:04 AM UTC
Well , now you tell me this ! How come you didn't say anything sooner ? Never good to keep a blonde in suspense you know she's less inclined to make cookies !
Thanks Keith , I do have a vice , but how would you set up the guide ? And will a pin vice work ? Shouldn't this be done with a high speed drill ? I would rather use brass rod for the strenght . Of cource option 2 is a good one as well
Posted: Saturday, June 26, 2010 - 05:37 AM UTC
I'd just clamp a piece of plastic or perspex in the jaws along with the rod and drill down through the centre...this is only theoretical btw.
I thought if you could get the bit started in the brass using the plastic or even perspex as a guide you might be able to drill through easier once it had countersunk the rod.
High speed of course would melt the plastic but hand drilled at least to countersink the rod may be worth a try first?
Posted: Sunday, June 27, 2010 - 05:28 AM UTC
Hi Keith , drilling the plastic rod was easy . I start a pilot hole with a needle and then start the hole with the drill bit . I's drilling into the brass rod which I wasn't able to do . Tried to start a pilot hole . Worked some what but can't get enough pressure on the bit to drill the hole with out it snapping first .
Washington, United States
KitMaker: 57 posts
AeroScale: 56 posts
Posted: Monday, June 28, 2010 - 08:42 AM UTC
Terri,
To drill the brass rod, try innealing the end of the rod first. Heat the end of the rod to red hot with a cigarette lighter. Let the rod air cool without quenching. The brass should be much softer now.
Mike
Mike the modelhound in Bellingham, WA USA
"No man is so hated as he who will drive the speed limit."
United Kingdom
KitMaker: 719 posts
AeroScale: 691 posts
Posted: Monday, June 28, 2010 - 09:01 PM UTC
Looking pretty impressive from here Terri- super work!
I would go for reducing the load on the booms- as the engine is the heavy part, could you drill pins into the wheels, so that the wings and fuselage are actually self-supporting, and the boom is under no load (except for the minimal weight of the tail)?
Posted: Tuesday, June 29, 2010 - 04:57 AM UTC
Terri,
Mike
Works for PE parts for bending , will have to give this a go and see how it turns out , thanks for the tip and the reminder
Posted: Tuesday, June 29, 2010 - 05:01 AM UTC
Thanks Ben , but I don't understand on " pinning " the wheels ? The wings and landing gear will be pinned in place , but how would this take the load of the booms ?
