After spending 3 wonderful weeks in hot Sweden I'm back home at the bench and would like to show you my latest built kit, which I finished early in July just in time for the expo in Lützen near Leipzig. It's the rare seen PZL 37 A Los from Mirage Hobby in 1/48 ....
.... the PZL 37 Los ("Moose") was built by Panstwowe Zaklady Lotnice and was one of the most modern aircraft of the Polish Air Force when WW 2 broke out. Development started in 1934. After 3 prototypes were built and tested the Air Force ordered 30 aircraft, named as PZL 37 A. In 1938 the aircraft was shown at the Paris Air Show and several countries were interested to buy or build the bomber in licence. Due to the outbreak of war, none of these plans were realized. The PZL 37 A had a single tail fin, while the PZL 37 B (and the final produced 37 A) had a double tail fin. The aircraft was powered by 2 licenced built Bristol Pegasus XX engine with 925 hp each which gave the aircraft a maximum speed of nearly 450 km/h in 3400 meters. The range was 1500 km with a bomb load of 2200 kg ....
.... I have built PZL 37 A No. 72.11 of the 212. Sqn. The aircraft was sponsored by several banks and handed over to the Air Force in Warsaw on the 8. December 1938 ....
.... the kit is from the polish manufacturer Mirage Hobby and I've had it for several years in my stash. The new Bombers 2 Campaign gave me the chance to build it now. It's a Short Run Kit and has its flaws. So the wings don't fit well to the fuselage. There are big gaps on both sides all around which I had to fill and sand. Also the fitting of the tail section was not without problems. Some more sanding here. But the most annoying issue was the fitting of the front clear parts in front of the cockpit. Another gap of 1-2 mm width showed up which I had to fill. I didn't want to use Evergreen profiles or white glue. So I ordered Micro Kristal Klear at my LHS and had to wait nearly 2 weeks for it to arrive at my door. In the meantime I couldn't work on the kit ....
.... for the main painting I have used Brown 381 from Revell Aqua for the upperside. It's the only tone I had which came close to the real one, though it should be a bit darker. For the underside I wanted to use the same light blue I've used on my Pe-2 Peshka but noticed there is not enough paint left in the tin. So I went for Light Blue RLM 65 from Agama, which is a bit too bright for RLM 65 in my opinion but here it fits perfect. The interior, wheel wells and bomb bays are painted with Aluminium 99, again from Revell. The decals are taken from the kit, which offers 3 options, 2 polish and 1 romanian. It's okay if you have thin decals but these are simply far toooooo thin and also brittle. So I had to do some surgery to rescue them. I've lost only one, the "Los" decal on the upper right side rudder. Needless to mention, that the kit is not weathered, or ....?
So I say "bardzo dziekuje!" for walking around my first polish aircraft. This is sure no easy kit and needs a lot of TLC but in the end I'm happy to have it in my collection now. If you're interested, have a look at my build during the Bombers 2 Campaign on pages 4-6. I think I needed 9 or 10 weeks to build it. More than usual for me. But now on to new sins!
Happy modelling!
Torsten
