Hello Boys...!!
At your request, totally out of the topic...
A little history of my Vacumn Box...
A take the materals from the favorite Artistic Warehause Shop of my wife... The box are used for bricolage, with decorative purposes; and at this latitudes we call MDF, some recycled wood...
After that I made the holes...
O.K. It was a lot of holes...
After that, the box was fixed to the white base suport with screws... And I glue the top suface (the suction surface)...
After that, You can fix the vacumn tube of the machine, and put the plastic sheet in between the removable top with the bolts (butterflybolts)
And... Bualaahh... You got all the thing...
I likes to fix the box to the workbench, that is way you can see the red metalic accesory... We call "Sargentos"...
Two considerations:
If you have a Electic Oven, Talk with your wife first... But, everybody says it works far better than the pistol...
And, May be necesary use some type of handgrip, and some "guide" to help a better aim in the moment when you drop the heated device against the suction surface...
I hope my English do not ruined all the explanation...
If you needs something else, Please, Ask again...
Thanks You Very Much
Diego
