SEAT MODIFICATIONS
I found a bit of time to start modifying the True Details pilots' seats. It has proved fairly easy, since the main thing necessary to achieve a better look is lengthening the seat backs.
As you can see, all I did was cut the top off with a razor saw, and insert a piece of styrene sheet in between. I may or may not add ribs to the seat back at this point. This is because I will be adding a seat cushion on the seat back -- just a piece of sheet styrene with rounded edges, and the ribs would be all but invisible.
I expect to paint both the back and seat cushons yellow chromate green to match the Eduard brass. You can get a sense how this will look below, using the brass pried off the old seats.
I haven't decided yet whether I will add shoulder belts. Depends on whether I see photographic evidence of their installation in an F model.
I do plan to make armor plate out of styrene sheet, using Karl's posted drawing as a pattern. I'm going to take a guess that there were no head rests above the seats, just bare metal.
Although my day job is slowing me to a crawl, I'm pleased with how the seats are coming along. I think it will be a significant improvement over what was there before. From the first photo you can compare the kit seat off to the right, and see the secured, inner chair legs on the "basement doors" off to the left.
Later Folks.
