A couple of work-in-progress pics.
I hope I am not boring the lurkers. At the very least you're being treated to a bravura OCD performance.
In do expect to get the inner bomb racks installed this weekend, with completed ropes.
Brian,
The rope really looks "in scale". Does it fit through the eyelets or did you have to glue it on top?
Quoted TextBrian,
It fits perfectly. Nice mating of materials. Glueing the ends together with crazy glue after passing through the eyes.
how you handle all four engines, which I'm guessing each will be to a different level of detail, as well as full blown wheel wells.
Of course the next milestone is when you button up the two fuselage halves.
Quoted Texthow you handle all four engines, which I'm guessing each will be to a different level of detail, as well as full blown wheel wells.
The engines will be fun. Probably my favorite part of the A/C. As for wheel wells, yes, though I'm not going "to reinvent the wheel" there. There's another online build where the guy has a how-to presentation and I will use that as a guide. Plus, my NC friend will be helping me with the hard parts.
Of course, there are a few things to be completed before the fuselage gets buttoned up!![]()
Brian,
From the angle in the pictures, the alignment looks to be off just a few mm. * * * If that's the case, why not glue the Bombay into one half, then work on the fit so that the other fuselage half mates correctly?
Quoted TextBrian,
I'll consider that. I agree that the pictures give a somewhat distorted view, from almost any angle, and was fessing up to that in the post.
Bottom line is that this isn't a show-stopper.
Certainly a major accomplishment in just test fitting the Bombay and taping the fuselage halves together. * * * Clearances, I had to wonder just how much of an issue is it? * * *
If you can live with just two oxygen bottles, then go for it. It's as per specs, and only you will ever know that there was a one time effort for four bottles.
Thanks for your support Joel.
I suppose this effort is something you couldn't pay someone else to do. [Private joke].
The clearance issue was not that great, but I really had to correct the gap between the pilots' compartment and the roof of the radio room. I believe I have finally located the main sticking points and eliminated them. The fuselage will be a slow, section by section gluing job, beginning with the bottom. But it should go OK.
Haven't made up my mind on the oxygen bottles yet.
Boy do I look forward to getting the fuselage done!
