RADIO ROOM FORWARD BULKHEAD ALMOST DONE
There is a little bit of touchup painting I have to do, and also a run of electrical wiring in the right front of the forward bulkhead, but this part of the build is basically done.
This provides the best overall view:
You will note that I followed Karl's suggestion and added a leather cushion below the bottom of the door.
This one gives a better view of the detailing on the right side:
Here is one that shows off some of the open door detail. I’m glad that the real thing has many pictures that show heavily worn interior because, intended or not, this surely has that “look”:
Finally, this one gives some sense for how this space will appear through the open radio room hatch:
After I finish adding the last run of wire on the forward bulkhead, I think I will be moving to the floor before I tackle the right bulkhead. The plan is to have it with an aluminum finish, but covered with nonskid between the forward and aft doors, and have plywood floor sections glued to the top of the aluminum floor to either side of that long central door in the middle of the floor. When that is done I feel the room will really start to come together.
