Quoted Texti didn't get a response so if i may i will repeat my request
first does anyone know what color should the AVG p-40b wheel wells should be? can't find any photos or documentation. also if any of you out there use mr dissolved putty or mr surfacer 500 to fill wing roots and seams what do you use to clean up the excess around the join with out damage to the plastic? i tried nailpolish remover and rubbing alcohol.
thanks- joe
Joe, try enamel/laquer thinner (while it is fresh) - but once the putty/surfacer dried hard normally it's impossible to remove with a solvent. For the wheel wells of a P-40 I'm not sure but should be the same color as the whole underside/-carriage.
Thomas![]()
btw: nice work on that ancient kit, you are going to overcome the issues...
thanks Thomas. i have made some more progress since i last posted. do you mean plain enamel thinner? lacquer would melt the plastic. i have wedged some plastic strip in the wing/fuselage gap i just need to sand it smooth and fill any holes with the dissolved putty. i will try the enamel thinner.
the underside will be light grey, the monogram directions call for interior green wheel wells and the academy kit i have says chromate yellow.not sure what british aircraft were painted
joe
