beginning shots on Airfix's 1/72 effort
Russell,
Great to see you moving on your 262.
Joe,
That microscale stuff with either sink into or bind well with acrylic paints. If you're using Tamiya paints you can wash/rub it off with a cloth and some water.
When I do my wheels, I paint them a dark gray then I weather them up a bit with radiating strips in black,gray and brown. Then I dirty up the part of the tire that contacts the ground with some light pigments. Once dry, I dust off the pigments with a brush. It's not a perfect method, but better than nothing. I try to avoid over weathering.
Gaz
I said to myself: not another Me262, let's not join this campaign... but I am weak and I have been following this thread for a while and you are doing a great and I am jealous. So here we go.
I am following Russell with the Airfix 1/72 Me262A.![]()
I was working this weekend on the cockpit and dry fitting the main parts. Cockpit is really simple and the fit is good in general, far from perfect, but the join between engines and the wings is diabolical. We will see...
Carlos.
Quoted TextI said to myself: not another Me262, let's not join this campaign... but I am weak and I have been following this thread for a while and you are doing a great and I am jealous. So here we go.
Carlos.
Hi Carlos, hopefully I can do a bit of trail blazing for you and light the way... I'll post pics soon, but I believe there is an easy fix for the wing and engine join... A bit of trimming is required to enable the engines to snug down...
Also, I'm of the opinion that the 2 parts that make up the cockpit cylinder shouldn't be glued together before inserting into the fuselage... I think the top piece should be glued to the fuselage first...
Let me try it out and I'll post up some pics soon so you can see![]()
