Thanks for the kind words on the Beau pix, to answer your question on the 455 Sqn Bird {and no I won't get mad at you - it's a question always argued about in the 'Land Down Under'}, the forward section of the cowling is not rust, but infact Burnt Iron, on all the Bristol Hercules engines the exhaust collector is the forward section of the engine cowlings, standard with the Swordfish, Beaufort, Beaufighter, Sunderland, Halifax, Wellington, Lysander and Lancaster II.
Regarding the RAAF 'Green Cat', I have a magazine on RAAF Camouflage for Catalina aircraft and it shows an Overall Green PBY 5a bird, so when I built my PBY 5a Cataliana, I chose to paint mine in the overall green scheme, because all the models I had seen previously showed either USN, RAF, RAAF cammo and the Green beastie was something different to look at, about 18 months after I had finished my model the RAAF turn up with their 1 to 1 scale Green Bird.
Staying with the Catalina subjects:-
Jan,
I can understand what your saying about copying idea's and I have no problem with that, afterall the forums are a place for exchanging idea's and techinques used, [I worked in a Hobby Shop for 15 years and modeller's regardless of being face to face, over the forums or over the phone, always have questions, relating to something on a model subject].
Going back to the 'Cat'
Step 1:-
The Red Oxide Primer is Humbrol #70 applied to the 'Canvas' area of the main wing and the control surfaces of the tail plane, this will sit for 2 days before I mask it off ready for the Humbrol #191 Gloss Silver.
The main wing is NOT glued to the fuselage, but notice in the fuselage pic the masking tape over the wing centre mounting and also this is a 72 scale bird.
