Excellent pic of an RAAF Boston during maintenance, note the nose mounted 0.30's, all the DB7b's, A20a's and A20c's the RAAF flew in operations had this field modification, straffing firepower fitted.
The A20 in RAAF service in the PTO was called a Boston {the same name the RAF had given this bird}.
Transformed from the older AMT A20b/c kit into a DB 7b Boston in 48 scale.
Modification of the Academy P 38e Lightning to F4-1a specs
Views of the almost completed F4 1a in RAAF service
Progress of the currant Italeri kit of the A20b/c Boston / Havoc
Repositioning of the undercarriage leg mounting points - moved forward a of an 1/4 inch, the pencil lines show the new location point.
Bomb bay made from .010 thou styrene sheet, as a means to hide the lead shot counter wieght, as this is being built as an RAF Nth Africa bird.
Gordon,
Sorry, the F4 1a that the RAAF had were the PR version of the P 38e.
The aircraft that I mentioned with bomb bays in each outer narcelle is the CA 11, this was a locally designed and produced bird that had 'Died before it was Born' 2 such aircraft where ever built and both were {sadly} lost in early and mid '44.
I had requests from countless people to produce this as a Multi Media kit in both 72 and 48 scales, based on the plans of the 1 - 1 scale bird, it is an interesting model subject.
Sorry for being
