Here is the Wirraway that I have down.
It is a conversion of the available T-6 Texan from either Platz or F-toys.
I have changed the wing and fuselage and the other pieces use the donor kits parts.
Here new rudder and Mg bulges added:
Interior framing added (I made a copy of the interior framing from a Foxone Lysander kit as a basis for the framing):
To represent the quite noticeable fuselage ribbing I cast this layers of the Lysander fuselage which had suitable ribbing effect and sanded it to it was almost transparent:
The wing was cut and straightened as well as having the tips extended and rounded (with pieces from a Ju88 kit!)
Wing and fuselage master finished. I have added the pronounced wing strengthening rib as well as the added Oil cooler and extra air cooler intake to the side of the cowling:
Painted in Polly scale RAAF paints and interior and turnover protection cage added as well as weathering done:
Cockpit added (used the F-toys one):
Need to add the aircraft letter 'D' as well as 3 bladed prop, large radio antenna and aerial and that should be it!
