Edward Scissorhands must have a brother in Finland. Eetu Tweezerhands. Pit is coning out nice Eetu.
Thanks, but isn't that a little early for compliments, I'm not done yet.
And yes, if you're wondering, it just gets worse...
When I got the bundle of cables going to the panel on the cockpit sidewall glued, I realized that the prominent fuel pipe with the clear section was missing altogether. So, I made one from copper wire, stretched clear sprue and masking tape. Out of fear that the instrument panel wouldn't fit with the pipe of the correct length, I made the front end shorter, in vain as I found out later and fixed that.
But before getting there, I got the main cockpit component finished.
Academy's kit was missing the bomb rack control panel from the cockpit, but AML's K4 kit has it both as a PE and resin part. The latter I took for this build, leaving the better detailed PE part for the original.
Before finally closing the fuselage, I'll have to do some research in case this particular plane didn't have it, although many Finnish G6s were supplied with the Jabo equipment.
While I was at it, I noticed the K4 kit had much better looking landing gear doors, and proceeded to swipe those to this build as well, as the limited edition kit offered both plastic and PE landing gear doors.
The AML parts are much better shaped, but also slightly thick (it's a limited-run kit), but fortunately that was easy to fix with a little work with sanding sticks.
And finally for this update, here's a shot of the cockpit, ready for closing the fuselage halves.
After the instrument panel fit just fine with fuel pipe in place, I replaced the missing piece with a length of stretched sprue painted yellow. (still to be cut down to size in this pic)
