Well I am underway with my 1/48 Academy Hawker Hunter F6 for the chequreboard campaign. At first glance it is a beautiful piece of moulding of this gorgeous aircraft. The well publicsed tiny bang seat has to be seen to be believed. It does bare a resemblance to something more akin to 1/72 scale. A pity really as it's a fair representation of the Martin Baker 3H ejection seat. I might try and make a replacement, but there a few resin seats to correct this problem. The ducting for the engines seem a bit complex, but they are fitting together really well. You just need to be patient and use a bit of tape to hold the bits together before applying liquid poly. The plate fitted in the air inlet supplied in the kit does not fit when the halves of the intake are joined. It was simply replaced with plastic card. I later found that they are not supposed to join with the upper and lower parts of the intake! Cockpit is completed, minus the seat. I have gone a bit over the top with colour I think. No wonder there is no pilot with all the red lights showing,
tim
