but the stripes are showing through the top roundels![]()
Bummox ,I've put a plea out for a spare set so I can double them up,otherwise I'm knackered![]()
It should be relatively easy to isolate the inner circle and spray with a little insignia red actually (blue looks fine in the pics). Go get a drafting template with circles and mask off the ones you don't need and spray right thru the correct sized one (or use it to cut out a mask if you prefer) - they are cheap (certainly cheaper than another set of decals):
You'll even have a chance to make the red look a little faded that way, which tends to look really good.
