Wow, you work fast, Torsten! They're both looking good. I, however, am slow
, but I have managed to plod onward a bit. . .
Added new cockpit floor details
The fuselage is used for different variants, and some surface details need to be filled and moved, note that Hasegawa supply a decal "hatch" for you to replace the molded-in detail which must be moved for an A5
The decal thing doesn't work for me, and though this may look like a lot of work, it only took a few minutes and is, to me at least, much easier than trying to scribe a new hatch and add hinge detail (if it's a shape that can't be scribed with an etched saw, I'm lost)
It would have been simpler to simply cut out the area with the existing hatch, move it, and fill the hole except for one thing: there is also detail molded onto the interior behind it.
The mold only took a tiny amount of rtv
Made a cutout in the area where the detail needs to go. The mold will simply be held in place, and resin brushed into the cavity from the back. The hatch detail has been poured and finished, but when I was uploading the last 2 days' pics, I discovered I'd forgotten to photograph it. I'll put up a pic on my next update.
The lower wings have inserts to accomodate different variants
Had to get these joints really smooth, as they're not panel lines on the real plane, and I'm planning to rivet.
As I said, I'm slow, so that's it for now.
Regards;
Automaton
