Update time for my entry.
Funny how loosely fitting locators seem to be somewhat of a theme with this kit. Not a big problem though, just a matter of gluing in some styrene sheet to make the parts fit snuggly. Perhaps the largest of these parts are the outer wings. These needed strips of styrene sheet on both sides of the locator tabs.
Then there's the ram air turbine mount. Small locator node and a big hole in the fuselage bay, here filled with a piece of styrene rod. A more appropriately sized hole will be drilled soon. I also added some detail to the otherwise empty space that is the RAT compartment.
Compared to the real thing, that's perhaps not even one third of the amount of wiring and components. But as I'd rather keep my eyesight and sanity, I just added some to make it more look less empty.
As with the RAT compartment, I applied some creative gizmology when adding a bulkhead and piping to the main gear wells.
Since the gear well detailing in the kit is not only completely fictitious. but the wells also get way too shallow from around the middle outwards, I didn't stress about the detailing too much.
While I was at it, I added some wiring to the sides of the nose gear well.
