Thanks guys. I stayed up late, well...late for me anyway, last night and got the canopy masked and shot the black undercoat on that. Still drying this morning. I used Humbrol enamel and with the high oil content it takes awhile. I will be painting this backwards from my normal routine. I usually paint the lightest color first, in this case the light blue bottom. But, if I do that, masking will be a lot more tedious...so, I will paint the camouflage pattern first, then mask that and paint the bottom.
Here's a is tip for you in regards to masking the canopy Jeremy. First, dunk the whole thing in future and set it aside before you do any building on the kit. This will give the future some really good time to cure rock hard while you work on the rest of the kit. When it is time to mask the canopy, attach it to the bird...permanently. Makes it considerably easier to handle and no finger prints on the inside. As there a lot of rounded corners on this things canopy, use a punch and some Tamiya tape. Punch accordingly sized discs that match the curve of the corner and lay them in. When you are done, your canopy should look like it has the measles.
Now, cut thin strips of Tamiya tape and connect the dots along the straight runs. I used larger discs for the faces of the canopy. Now larger pieces can be used to fill in the fields of the canopy. Using the discs is a lot easier than trying to cut tape thin enough to follow the contour or using liquid mask. Hope this helps.
The troop doors are semi attached with white glue for painting, and the troop area is stuffed with some Kleenex. Once the black on the canopy dries, she'll be ready to receive her colors. Trying to wrap this up before next Friday. I'm leaving on vacation and don't want to leave this one hanging...
More to follow soon. "Q"
